997TT steering feel too light?
Old Jan 20, 2010 | 02:54 PM
alan6888hk's Avatar
alan6888hk is a glorious beacon of lightalan6888hk is a glorious beacon of lightalan6888hk is a glorious beacon of lightalan6888hk is a glorious beacon of lightalan6888hk is a glorious beacon of lightalan6888hk is a glorious beacon of light
Hi guys,
I have a 2007 997TT, love it so far.
Only thing I really wanna change is the steering feel. Used to have a 03 996C2, steering of the C2 feels much stiffer/heavier. Unlike my 997TT, kinda soft as a sports car, maybe too user friendly just like the hydrolic clutch?
I personally like more heavier/stiffer steering. Is it vary from model years?
Do you guys have the same feeling? Anything I can do to make the steering stiffer???
I appreciate your reply,
Thx,
Alan
Old Jan 20, 2010 | 03:38 PM
gmoney's Avatar
I think the 997TT is stiff and borderline numb compared to the 2WD Carreras at least! Dropping it and tossing on some sways helped but still, light is definately not how mine feels. I do have the thicker steering wheel leather which definately has more meat to it which can alter how it feels in your hands crazy as it sounds.
Old Jan 20, 2010 | 03:51 PM
alan6888hk's Avatar
Thx for the reply gmoney!
However, your reply kinda scared me. Sth wrong with my car? what's your MY? 07 as well?
I have the thick techart multifunction steering wheel and RSS sways, but doesn't seem to help. Still feel kinda light.....
Cheers,
Old Jan 20, 2010 | 04:12 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
change your front drop links to stiffer ones.
Old Jan 20, 2010 | 05:09 PM
gmoney's Avatar
Mine is an 08 and the only time it feels light is under hard acceleration
What settings are the sways on?
Old Jan 20, 2010 | 06:37 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Suspension mods, tightening up the front and getting a more track oriented alignment will give you some more feedback and a tighter overall feel.
If the car hasn't been aligned since you picked it up check it out, depending on how it was driven and how long it went since an alignment could be a bit off even if it tracks straight.
Old Jan 20, 2010 | 07:25 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
+2, light wouldn't be a word I would use to describe the steering of the TT.
The steering does get lighter under hard acceleration.
How would you describe the steering on an MB or a Lexus???
Try an alignment and sways like the others stated, but first have the car checked out.
Old Jan 21, 2010 | 01:01 AM
alan6888hk's Avatar
Thx a million for all the replies. Really appreciate you guys' help.
I would discribe MB or Lexus, if the scale is 1 is heavist and 10 is the lightest. I would say MB and Lexus are like 9. And I would describe my TT like 6?
I guess I really wanna take mine to the dealer to check it.
Here is the list of suspension mods i have now.
Bilstein B16 Damptronic
Rss front and rear sways(front the softest, rear the hardest, however I don't think the sways help on the steering feeling except feeling much better when I am in corners, stiffness of the steering feels the same before and after)
How would you guys describe your steering? 1-10? Did you guys do anything to the suspension to make it this stiff? or It came factory like this?
THx for the help again guys, everyone of you are being very very helpful.
Best,
Old Jan 21, 2010 | 05:00 AM
Alex_997TT's Avatar
Alex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond reputeAlex_997TT has a reputation beyond repute
I prefer heavier steering too which is why I now run with these (test3) settings:
Note the large positive front toe, and not a huge amount of front camber. A lot of tuners set front toe to be either 0 or toe out (minus) so that turn in is quicker. I have high positive toe as 1) I like heavier steering 2) I don't like fighting the steering wheel on rough terrain 3) as I have more power than the stock car on acceleration the wheels naturally toe out (go more neg) and so more power = more toe out on hard acceleration.
To reduce squatting (light steering on acceleration) you need to have Damptronics and lower the car, ensuring the rake is still about 1 degree nose down (my ride height settings give this).
Sway bars wont make any difference to steering feel as far as I am aware. You can increase/reduce grip on one end of the car by tightening/loosening the sways on the opposite end of the car, but that's about it. Note, if you stiffen the rear sway to give more front end grip and thus less understeer, you have to bear in mind that then the point where you lose grip is much more sudden ie. you have to correct much faster.
Old Jan 21, 2010 | 12:39 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Hey Alan, how have you been! Long time!! I have similar feeling with my stock steering wheel. I know you already have TA but if all the alignment thing didn't work. Think about a smaller 340mm wheel. It tighten the steering feel alot, it work well with me!
Old Jan 24, 2010 | 12:04 AM
darmawaa's Avatar
darmawaa is infamous around these partsdarmawaa is infamous around these parts
Change your front tire to 245/35/19
I did mine, steering feel heavier, also higher sidewall means better pothole resistant.
Old Jan 25, 2010 | 01:20 AM
alan6888hk's Avatar
Thx for the useful information Alex.
I am looking for a place who can do a corner balance and a good alignment as well. Hope that fix my light steering problem. I will print out this chart to do exact alignment
Hey Ray, long time no see! How was your trip to HK? Hope you well.
I am thinking change mine to a small steering wheel too, I have to try yours again see how it feels!
Thx for the input! Might try this out as well.
Old Jan 25, 2010 | 01:23 AM
alan6888hk's Avatar
Is it true that the factory multifunction steering wheel has a bigger diameter compared to the factory sport steering wheel? I drove my friend's 997C2S which has the sport steering wheel, feels like the steering is little stiffer, and the steering wheel feels smaller too, is it true? or it's just my wrong feeling? Even I have the TA thick multifunction wheel, still feel bigger then the factory sport one..
Old Jan 27, 2010 | 01:11 AM
alan6888hk's Avatar
any input?? thx guys
Old Jan 27, 2010 | 03:02 AM
Alex_997TT's Avatar
No idea. I have driven many Turbos with both sports and MF (the thicker version in my Turbo) wheels and I didn't notice any difference other than not having those thick parts above where you thumb goes.
Personally I don't like the Porsche sports steering wheel. I'd much prefer a Techart or even an Audi/Lambo sports steering wheel myself.
Perkman87
Nov 19, 2015 05:31 PM
03EvoIII
Sep 21, 2015 04:38 PM
Michael_s
Sep 11, 2015 08:03 PM
thegrillboy
Cayenne 958
Aug 22, 2015 09:24 AM
pwdrhound
Aug 20, 2015 05:54 AM
