Softronic Tune for 997.2TT... First Ever PBox Run on 6Speed!
Old Jul 4, 2010 | 06:06 PM
WhiteKnight's Avatar
WhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to behold
Originally Posted by artur777
I think you should try to avoid starting with launch control. Without it you will have better times. We have Turbo PDK with ECU tune and stock exhaust with folliwing times
0-100 3.1
0-200 10.45
1/4 mile - 10.95 at 204 kmh
We started with:
1. Sport Plus Mode "D"
2. A/C off
3. PSM off
4. Without launch control but from 2000 revs pressing brake and gas simultaneously
Which ECU software do you run ?
Old Jul 4, 2010 | 07:10 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
0-100 3.1
0-200 10.45
We started with:
2. A/C off
3. PSM off
i was about to say that karrim try what the gentleman mentioned
we all know u should get an exhaust system but wont lose any thing if u tried this ..
m glad u worked the tune out ..
Old Jul 5, 2010 | 12:35 AM
k_ddsl's Avatar
k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !
My thanks go out to everyone who chimed in.
I will try the suggestions and will revert with PBox and Durametric info.
It will take a few of days though.
Old Jul 5, 2010 | 01:28 AM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Also try your car when it is cold not after a long ride.
Old Jul 5, 2010 | 01:40 AM
k_ddsl's Avatar
Will do John. Thanks.
Old Jul 5, 2010 | 06:41 AM
bbywu's Avatar
Do not do a WOT run without warming up your car.
- bob
Old Jul 5, 2010 | 08:06 AM
SpunkyQ8's Avatar
SpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond repute
- bob
True that ..
Karim,
Bro i'm kinda disappointed with the numbers. Regardless of the exhuast you should have minimum gain of 50hp including the air filter.
Hence, try and datalog with a WOT run share it with the guys ..
Cheers,
Old Jul 5, 2010 | 09:06 AM
The Bogg's Avatar
It felt like I was in Kuwait yesterday, hit 36celsius here yesterday!!!!! At least the a/c in this car is Amaaaaaazing. I had it near it's lowest fan setting and it kept the car nice and cool.
Old Jul 5, 2010 | 09:27 AM
vividracing's Avatar
Dont run the car in sport for top end numbers. I am sure you saw my review and dyno tests. Sport mode gives the car low end boost and then fades off at the top end because of EGT temps. If you try and run it back to back, it becomes slower. My personal experience... Show us the 60-130 times? The best 0-60 on my 825HP 6psd I could get was 3.4secs.
Old Jul 5, 2010 | 10:03 AM
SpunkyQ8's Avatar
Originally Posted by vividracing
Dont run the car in sport for top end numbers. I am sure you saw my review and dyno tests. Sport mode gives the car low end boost and then fades off at the top end because of EGT temps. If you try and run it back to back, it becomes slower. My personal experience....
Good point!
I might as well add to that try Sport mode (faster throttle response, quicker shifts, stiffer suspension)only mode NOT Sport plus (same as Sport add to that 10 sec. overboost) ..
Old Jul 5, 2010 | 12:06 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Why have sport mode then? Just so you can switch between low and top end performance? Doesn't make sense to me. Sport should be more aggressive all the way through. If not, then the system needs optimizing.
Old Jul 5, 2010 | 12:08 PM
That is how the car works from Porsche, it gives initial boost for X amount of secs and based off the EGT temps it then shuts off. The feature of Sport to have 100% throttle response is there the whole time.
Old Jul 5, 2010 | 01:31 PM
TTdude's Avatar
What is your definition of top end? Skand has reported 0.5 sec faster for 100-200 km/h with sport over non-sport which is within the range that is being tested here.
Old Jul 5, 2010 | 01:35 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I was reffering to my cars tune (APR) where overboost is deleted from sport function...I am not in position to know how each tune operates...
Old Jul 5, 2010 | 01:36 PM
TT Dude - Lets not ruin the OPs thread. We are not apples to apples here. Climate/trans/car/mods. But search any dyno I have independently done here on the 997.1 or 997.2 Turbo and you will see.
