Boost Recirculation Valves
Old Sep 2, 2010 | 06:31 AM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
I ordered a set of Agency Power BRV's from Vivid tuesday and I plan to install them this weekend. Besides having to put them together before install, is there anything special I need to do while im installing them on the turbos?
This is my first turbo car and I want to do everything correct the first time around.
Old Sep 2, 2010 | 06:59 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Make sure you you follow the assembly instruction correctly else they will leak.
Old Sep 2, 2010 | 10:37 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
just installed them a few days ago, pretty easy to do, do a search with BRV in the title and you will see a thread by Dan from vivid explaining how to put the valves together. Then its really just a matter of taking out the old ones and putting in the new ones. about 15 min for passenger side, about 30 min for driver side due to location being a bit of a pain to reach and also removal of driver rear wheel
Old Sep 2, 2010 | 10:41 AM
PacMan Z's Avatar
Thank you!
Old Sep 2, 2010 | 10:56 AM
dinorocz's Avatar
Originally Posted by PacMan Z
Thank you!
Let me know if you have any other questions, Ill gladly help
Old Sep 2, 2010 | 12:17 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
What advantage do aftermarket BRVs provide over stock?
Old Sep 2, 2010 | 02:10 PM
gt2rs6's Avatar
gt2rs6 has a spectacular aura aboutgt2rs6 has a spectacular aura about
dino .. did you install the 50-50 valves?? the ones that half vent to atmosphere...
Mike
Old Sep 2, 2010 | 02:16 PM
PacMan Z's Avatar
Thought those were only possible on the 996tt
Old Sep 2, 2010 | 02:24 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi!
Please tell us if you feel some difference before/after...
Old Sep 2, 2010 | 02:56 PM
gt2rs6's Avatar
sorry i did not even know they werent possible on a 997... you may be right sir
Old Sep 2, 2010 | 03:13 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
David - the stock BRV's can leak/tear if you are running higher HPs. I replaced them on my Cayenne Turbo and 997TT.
Old Sep 3, 2010 | 06:32 AM
dinorocz's Avatar
Believe it or not I was a bit skeptical at first. I have a softronic tune and full fabspeed exhaust. The car hauls a$$ and when your in 2nd at 4k it just slingshots.
After installing the brv's I noticed that slingshot feeling disappeared which got me a bit worried. I decided to give it a few days to get used to it and if I didnt like it, it was an easy change to go back to the stock brv's.
The other thing I noticed, is that between shifts, the car held the boost so that when I upshifted I was already on the gas and moving, it gave it the feeling as if I never let off the gas when shifting (if that is clearer).
All in all, I am quite happy with this little mod and would recommend it to others.
Old Sep 3, 2010 | 08:50 AM
fastlaw's Avatar
fastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud of
I dont understand. it sounds like you are saying that it reduced how hard your turbos hit. yet, you're happy with it?
Old Sep 3, 2010 | 09:51 AM
dinorocz's Avatar
it gave it a more linear feel and also the biggest benefit from my perspective was the boost staying up during shifts.
Old Sep 3, 2010 | 09:54 AM
fastlaw's Avatar
I am by no means an expert. But, what you describe to me sounds like a leaky valve.
