Summary about Porsche reaction with more than 1000hp
Old Jan 21, 2011 | 02:44 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
Post Summary about Porsche reaction with more than 1000hp
after long reading hard driving and allot of analyzing
i've found that with very high power im facing problems with traction even if i disconnect the traction the car wont disconnect the traction 100% there will still be traction !
EVOMS 4.0 Ltr
The problems we faced were all due to the OEM PTM (Traction management) system preventing us to make a clean WOT run. The car performed flawlessly at 25 PSI of boost where it went the fastest speed. As soon as we turned up the boost / power, the wheel slippage caused throttle cut as soon as we shifted into 5th gear. The throttle from 5th gear on was reduced to 60%. We tried everything we could throughout the weekend to correct this in the software as well as different driving styles, tire sizes, etc but we could not get a clean WOT pass with all of the power on board.
and later i went back to old Threads and found out that
Evoms faced the same problem with there 4.0Ltr 1200Hp in the texas mile and that was there major issue for not accomplishing there target!
pls check the vid in the run @ 2:20sec
http://www.youtube.com/watch?v=DRCd3mrbZdk
in other hand i also found out that the GT2 react absolutely different than the 997tt in the GT2 one of my frnds here running the GT3076.82 Protomotive package when he set the high boost disconnect the traction control and run a test Run all signs flash on the board which means the car has 0% traction control in this condition the car react insane and like a wild animal
Old Jan 21, 2011 | 03:27 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
Have you figured out a solution? How about Motec?
Old Jan 21, 2011 | 05:30 PM
yalmutawa's Avatar
motec ? i believe evoms should come out with a solution
Todd in protomotive is working on 5 engines in his work shop 2 of them will go for 997GT2 which m sure will not face problems 3 m not sure
but am sure he'll try the engines on 997TT and if he run it on streets he'll defo face the traction issue but on dyno he'll not
Old Jan 21, 2011 | 05:51 PM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Porsche marketing material states that "if you'd rather enjoy your 911 Turbo unassisted, PSM can be set to standby at any time". The key is "standby" although the button says off.
It is never completely turned off.
Old Jan 21, 2011 | 06:13 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
Almost all of these systems will give you more rope to play with but not enough to hang yourself with.
Old Jan 21, 2011 | 06:47 PM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
^^^LOL
try disconnecting one of the ABS wheel sensors?
Old Jan 21, 2011 | 07:17 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
FYI: Todd’s car is two wheel drive. They removed the front drive train (well, at least it was removed when I saw it). So I guess they are playing half the traction you are??? When I spoke with Todd in early Dec he mention they had difficulties trying to control the wheel spin and getting it to “hook-up”.
Old Jan 22, 2011 | 04:25 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
have you tried the hand break trick ?
Old Jan 22, 2011 | 04:43 PM
yalmutawa's Avatar
but it absolutely different in the GT2 as i mentioned before ..
LAMFO Ruf-Turbo u remind me in a joke when a stoned drunk guy decided to hang him self he set the rope to hang him self his frnds enter the room and sow him hanging him self from his legs they sow him hanged up side down they asked him what are you doing he said i tried hanging my self from my neck i almost died so i decided to hang my self from my legs
Old Jan 22, 2011 | 04:44 PM
yalmutawa's Avatar
how to disconnect it ?
thats a different story hahahah
Old Jan 22, 2011 | 05:10 PM
Jim Campbell's Avatar
Jim Campbell is infamous around these parts
http://www.proefi.com/Porsche.html
It's an untapped market really! Its kind of ridiculous that Porsche has the least aftermarket support for engine management.
AWD motorsport was working on a standalone solution i think.
9FF came across a 375kmh speed limiter on their 997 cars when the took them to nardo. It took them by surprise as their 996 cars weren't affected by any limiter. Very strange that anyone would bother fitting a 375kmh limiter, the idea of 375kmh and limiter in the same sentence is ridiculous.
Ta
Old Jan 23, 2011 | 01:19 PM
yalmutawa's Avatar
hahhh now the 996 boost gage can read what ever boost comes to it but the 997 boost gage will only read 1.2 as a max on the 997tt and 1.4 on the gt2 boost gage and there's another undiscovered thing called 375 speed limiter lol ridiculous i wont bother and ask why !
Old Mar 5, 2011 | 07:43 PM
Meshari's Avatar
Meshari is infamous around these partsMeshari is infamous around these parts
Removing the Front Drive Train would make the car a Vette, yes it'll spin.
Old Mar 5, 2011 | 08:50 PM
yalmutawa's Avatar
not only spin like a vette
GT2 is a 2 wheel and every one knows what does porsche engineers means imagine all of these engineers worked on a car a rear wheel drive car and its called the widow maker
what do u accept from a car 4 wheel drive converted to 2 wheel drive !
Old Mar 6, 2011 | 01:45 AM
RUF QTR's Avatar
RUF QTR is just really niceRUF QTR is just really niceRUF QTR is just really niceRUF QTR is just really nice
Gerhard from RS Tuning told me they use a special calibrated Motec ecu for anything more than 730hp...
