Differences between 997 GT2 and GT2RS
Old Mar 29, 2011 | 10:46 PM
Turbo Fanatic's Avatar
Is there any comprehensive info on this?
One thing I do know is that the weight of the GT2RS (~150lb less thank the GT2) is widely marketed with the free A/C delete which accounts for about 75lb.
Old Mar 29, 2011 | 11:11 PM
bbywu's Avatar
FWIW, part numbers for pistons and conrods are different on the RS. Turbochargers are the same.
Old Mar 29, 2011 | 11:23 PM
Interesting! Same compression ratio?
Old Mar 29, 2011 | 11:33 PM
bbywu's Avatar
997 GT2 has a compression ratio of 9.4:1
The GT2 RS has a compression ratio of 9.0:1
Old Mar 29, 2011 | 11:56 PM
speed21's Avatar
Do you have the part numbers for the pistons? I'll see if they cross reference.
Old Mar 30, 2011 | 12:33 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
During the past,I ve checked some parts for Bob and If i recall correct pistons were different...As for rods I am almost sure they differ...
Old Mar 30, 2011 | 12:57 AM
speed21's Avatar
The catalogue usually specifies differences. I assume these are Mahle? Anyway no biggy.
Old Mar 30, 2011 | 01:04 AM
PET doesnt specify brands...just different part numbers!
Old Mar 30, 2011 | 02:14 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
I thought 996TT/GT2 were 9.4 rated and 997TT/GT2/RS 9.0 ?
Old Mar 30, 2011 | 02:20 PM
bbywu's Avatar
My error, you are correct.
http://press.porsche.com/news/pdf/2008_GT2_Specs.pdf
Old Mar 30, 2011 | 02:21 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
We had one on the lift here for a little while and the turbochargers are different. Our initial impression is that they're the VTG's off the .2 turbo, or very similar in size. We didn't have enough time with the car to really "explore"
Correct on that one.
Don't quote me on this one, but I *think* the intake manifolds are different too. Again, not sure...
Old Mar 30, 2011 | 02:27 PM
bbywu's Avatar
Hi Tom...
I thought the turbochargers for the GT2, 997.2TT and GT2RS are all the same?
b
Old Mar 30, 2011 | 04:25 PM
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
Well the part number of the intake manifold is different but my tuner has seen them next to each other and they looked absolutely the same with standard aluminum GT2! I wish someone would know if there is really any difference really in the RS intake..
Old Mar 30, 2011 | 07:19 PM
Alcav5's Avatar
Alcav5 is a jewel in the roughAlcav5 is a jewel in the roughAlcav5 is a jewel in the rough
From another angle,
On Cars.com there are:
  • a new RS for ~$273,000,
  • an '09 (600 miles) for ~$182,000 and
  • an '08 (16 miles)for ~$180,000.
Is the new RS really worth almost $100k more from its predecessors... from a technological & performance standpoint?
In case I hit it big , I need to plan...
Last edited by Alcav5; Mar 30, 2011 at 07:22 PM. Reason: indicated wrong web site...
Old Mar 30, 2011 | 07:29 PM
There is no question that the RS is a special car.
I guess my point is that for 110-130K + a flash isn't an GT2 close enough?
