Mobridge Bluetooth & Ipod: Actual Users' Experience?
#61
The only reports we had over the years on static was from the aux inputs, and a simple ground fault isolator solved that one. No issues like that from standard ipod cable or connection.
Bluetooth streaming on the Dension is fine and should give you very close to what you'd have with iPod direct connection. Have you tried an alternate phone/device to see if it's the same? Happy to help our customers anytime - just email me.
#62
Eric makes a good point - I've tried only Apple based products, and don't have access to other brands - every seems to have iPhones where I work. Apple has notoriously bad behaving Bluetooth protocols.
#63
#64
I was thinking about doing a Dension or a Mobridge for bluetooth and iPod interface. Instead, I decided to get rid of the crappy PCM2.1 navigation all together and went with a JVC KW-NT800HDT. This is a 7.1" navigation screen with iPod, Bluetooth, A2DP streaming, etc. This particular unit has an SSD, so startup times are lightning fast (faster than even the iDrive in my 2012 M3). Has a great POI interface, lifetime traffic, etc. Computation time is very good, for changing routes, etc.
So far, the navigation is really good, and the bluetooth quality is fantastic. It is, at least subjectively, at least as good as the factory bluetooth in my M3, which is saying something because the Porsche is a significantly louder car.
I had a couple of quirks, first the JVC doesn't like the speed signal the MOST-HUR puts out (Pioneer decks are compatible, but not the JVC) but I just updated the firmware and disconnected the signal and it works fine. Also, my MOST-HUR was set too loud and I got some alternator noise and white noise but only between songs. I adjusted it, thanks emails from Loi at Eurospeed Motorsports, and it is solved.
I did the install myself, with the Eurospeed Motorsports kit and I was totally thrilled, very easy install. Definitely time consuming but fun. I ended up spending $800 for the install kit and $800 for the deck off Amazon. Ended up spending a little more than the options that integrate with the factory head unit, but ended up with a *much* nicer navigation system. Also, album art and full integration with my iPhone should I so desire, rather than a crappy interface shoehorned into the CD changer controls.
#66
Everything else works fine.
#67
This is basically the problem with mobridge, what did you do to adjust this? An adjustment on the JVC unit or in the car?
#68
On the MOST-HUR, you connect a USB cable directly to it and adjust the volume. I don't know if the Mobridge has adjustable gain. It wasn't with the deck or car.
#69
#70
Very nicely done - congrats. This Ipod/bluetooth issue is a PITA for sure - unfortunately I need the phone function and love the Ipod function so there is no way around it. With respect to replacing the PCM with JVC, don't you miss some important functions of the stock PCM when you do this? I don't have manual with me (anyone correct me as needed), but isn't the default temp of the car's climate system set with the PCM? I think some setting of TPMS burried in the menu somewhere too?
TPMS can all be done through the gauge menu, no problem.
#71
Hi Guys,
I've recently got my mObridge working again with the 1.9.4 software update. It has been out of service for some time.
Quick question. Why doesn't the system remember the last song you were playing before you disconnect the iPhone from the connector?
It's quite annoying having to go through my playlists again!
Cheers
Cheers
#72
Hi Guys,
Cheers
Cheers
#74
You mean if you remove Ipod from Dension and re-plug it later it remembers the last song? Are you sure about this, if so that's great!
Ok so MoBridge might have been a minor mistake on my part. Thought I did my research carefully but clever salesmen took me straight down the garden path.
Kidding aside, MoBridge is still in my car and the phone function is still a perfect 10. The audio function used to be an 8 for the beep, but you really don't hear it much and it ceases to bother me, so now it's a 9 :-). The quality of the audio itself is fantastic as long as you use loss-less conversion. I am so afraid of my car's temperamental electronics that I am probably stuck with it forever.
#75
Not that anyone may care since I seem to be the only one on the forum with this MoBridge system , but I have some screen shots, might as well post.
Below is screen displaying "London Calling," first screen shows how you could play througth Playlist, or Album, or Artist, etc. Third shot shows phone number, which has continued to function flawlessly with OEM like voice quality, with both Samsung Epic 4G and Samsung Galaxy SIII.
Once every few months I still get an error message about not being able to find CD Changer, but extremely rarely so and error message easily clicked away.
