Cel - p0021
Old Oct 11, 2011 | 03:25 PM
  #46
The Bogg's Avatar
Originally Posted by Steamboat
My motorman indicates there is quite a bit of additional work that needs to be done once the motor is dropped and the cams exposed in order to install new rods and whatnot. Probably something in the neighborhood of 25 hours +/- He advises checking with your local builder to get his estimate. Hope that helps,
That's useful info, thanks a lot. Rep points 4 u.
Old Oct 24, 2011 | 06:14 AM
  #47
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
well , after reading all posts i woulk like to know , what if some one do not have cable to check codes .. what signs you will notice from driving the car ?? is the car will be low in power ?
Old Oct 24, 2011 | 10:09 AM
  #48
The Bogg's Avatar
you'll get a cel and you'll feel a bit of power loss in the midrange (that's where I noticed it most).
Old Oct 24, 2011 | 04:47 PM
  #49
speed21's Avatar
Have you had yours dealt with yet?
Old Oct 26, 2011 | 12:02 PM
  #50
The Bogg's Avatar
The cel hasn't come back and the butt dyno and pbox indicate that everything is fine. I know it could be fixed under warranty but since the dealer doesn't pin the camshafts the problem could return so I will leave things alone for now and wait and see if the cel returns. Then I'll have to decide what to do...
Old Oct 26, 2011 | 04:40 PM
  #51
speed21's Avatar
Oh well, fingers crossed then boggy. Hope it stays away but if it surfaced once then thats one time too many if you know what i mean. Sure hope i never get it.....touch wood. It certainly sounds like a proper PIA to get fixed plus you also may have the issue of arguing the toss because of mods etc. Maybe.
Old Dec 26, 2011 | 07:47 PM
  #52
GTEE83's Avatar
GTEE83 is infamous around these parts
FYI, my car came up with the CEL a week ago and I got it into the dealer today. They are expecting to get my cams on Wednesday, and I will hopefully have the car some time this weekend. Anybody out there know how many times this has happened?
Old Jun 28, 2012 | 04:26 PM
  #53
The Bogg's Avatar
Well it looks like the CEL is back, along with the symptoms. Damn. Does anyone know if Porsche has developed a real fix for the camshaft issue? If they just put in another camshaft that will potentially do the same thing then I'd rather just pay and get the camshafts pinned. thoughts?
Old Jun 28, 2012 | 11:52 PM
  #54
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Asher, If you're going to put in new cams, just get them pinned before they go in. It would only take 10 min or so to insert the pins. Give TK a call.
Old Jun 29, 2012 | 04:23 AM
  #55
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
I have the same issue. Dealership has changed cam position sensors, inspected cams. I still have Cel returning. Funny thing is that the cel clears it self. I have asked why I'm having this issue from day one of ownership and the dealer can't give me a answer. There is a problem and Porsche doesn't have a answer. My car runs strong even with the check engine light on. I just hate having a intermittent check engine light. Dealer dose to seem to be in a hurry to fix the problem. My certified warranty is running out early next year.
Old Jun 29, 2012 | 08:25 AM
  #56
The Bogg's Avatar
Mine cleared itself last year also after a hard day at the track! I noticed that I get the CEL shortly after changing the oil. I wondered if tiny bits of paper towel (from mopping up the oil in the filter area) were clogging the holes in the camshaft so this time I didn't use paper towel - I used a syringe and needle to empty the oil filter housing. I'll drive the car hard and see what happens. My cpo warranty runs out early next year also. I had the actuators changed out last year.
Old Jun 29, 2012 | 08:27 AM
  #57
The Bogg's Avatar
If the dealership does it I'm not sure they'd be willing to do this (I'll ask). If it ends up on my dime then I'll get the engine built (not at the dealer) at the same time and have the cams shipped to Todd for pinning.
Old Jun 29, 2012 | 02:44 PM
  #58
M3 S3-R's Avatar
At this point I would be surprised if its a dirty oil issue. My old is changed ever 3k. Dealer did mention fault could be caused by dirty oil.
Old Jun 30, 2012 | 07:03 AM
  #59
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Is the actuator the same thing as a variator? I had both variators replaced when my motor was rebuilt by Evoms after it threw a CEL when initially reassembled. They indicated when the variators become contaminated, which apparently happens quite often and easily, a CEL is sure to follow. No issues now. Best,
Old Mar 19, 2013 | 04:22 PM
  #60
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Bringing up old thread here but any new news on this subject?
