Dyno Time
Old Jan 16, 2012 | 11:32 AM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
Dyno Time
This weekend my brother and I are going to have the 997tt dynoed for baseline numbers before we send out the turbos for larger billet turbines.
Should we have it dynoed under awd or disconnect the front drive shaft and do it rwd?
Old Jan 16, 2012 | 02:07 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
It doesn't really matter....I'd do whatever you have access too.
In your case, your using the dyno to just get a before/after comparison, so the only thing I'd do is make sure you use the same dyno each time.
What turbos you going for?
Old Jan 16, 2012 | 02:31 PM
The Bogg's Avatar
I debated the before and after dyno testing but decided to put the money towards the pbox instead. I logged data for the stock car, car with just tune and exhaust, and car with upgraded vtgs added (and clutch).
I think the important thing is the consistency as Tom indicated - if you have access to someone with a linked 4wd dyno then you don't have to remove the front driveshaft, otherwise you do.
Old Jan 16, 2012 | 05:14 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
you guys are working on the hot sides or the cold sides? I don't know of anyone porting the VTG hotsides yet
Old Jan 16, 2012 | 05:53 PM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
I think Proto does...
Old Jan 16, 2012 | 06:00 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I would suggest cms upgraded 68mm turbos ! And get a vbox its better to compare your before and after times !
Good luck buddy and keep us posted !
Yousef
Old Jan 16, 2012 | 06:56 PM
PacMan Z's Avatar
cold sides.
Old Jan 17, 2012 | 07:27 AM
We do some porting to the hot sides of ours. There's only so much you can actually do, but there's a tiny bit of room to improve.
Found a couple pics for comparison...
Old Jan 17, 2012 | 08:35 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Mine are ported since 2009 by proto
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Sep 1, 2015 03:16 PM
orbelo
Aug 30, 2015 12:26 PM
vbb
Aug 21, 2015 10:17 PM
