amplifier not working or what !!!!!!
Old Jun 10, 2012 | 09:47 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
yesterday , while am running the car suddenly the Stereo and music stopped , than a msg apeared into the screen ...
sometimes once i switched the car on , the music turn on and work with no issues but after 10 mins or 15 mins , the music stopped and the msg apeared again , so whats wrong ? is it the AMP or just fuse ?? or what ?
thanks in advance
Old Jun 11, 2012 | 08:05 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I have had the same issue twice now. Restart the car and all is good. I would be interested in what you find out. I need to take a picture like you did. So, the next time I go to the dealer I can show them I am not crazy.
My car is a 997.1 and it also has the "factory" SAT radio module from the cayenne. I am thinking that could be this issue. I think the SAT radio sound quality sucks. So, I let my subscription die but there were time when I would try to use it and it would not work. The radio could not find the sat radio module on the fiber loop.
Good luck.
Old Jun 12, 2012 | 12:14 PM
ysfg35's Avatar
dealer did not solve this issue in my case , running the car with out music is
Old Jun 12, 2012 | 12:33 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
Yussef what did the dealer say if he couldnt solve the problem?? No solution?
Old Jun 12, 2012 | 12:45 PM
ysfg35's Avatar
in fact , they said i should replace the whole music system, cost $3500 !!!!! to be honest they even Did not give me convincing reasons , and i felt that they do not know what is going on !!
Old Jun 12, 2012 | 01:05 PM
Carlitos way's Avatar
Carlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really nice
You got a gremlin eating your wires!
Old Jun 14, 2012 | 08:17 PM
ysfg35's Avatar
any one ???
Old Jun 15, 2012 | 11:09 AM
function12's Avatar
Old Jun 15, 2012 | 01:13 PM
bbywu's Avatar
Yousef, if you are getting an intermittent error saying that nav, amp, phone, and CDC are all not available, you have a problem with your MOST fiberoptic circuit or the control unit in your PCM is faulty.
When you get the error, do you have power to each of the units listed? IE does your dvd/nav eject? CD changer eject? I have a hard time believing it's simply a fuse issue - if the fuse was out, the system would stop working completely, not intermittently.
Is your audio system stock? Have you added an iPod interface or aftermarket amp and speakers?
Old Jun 15, 2012 | 02:10 PM
ysfg35's Avatar
well yes you are are right , i got the error once i switch on the car , sometimes i switched the car off then back on ! everything works but after 10mins or less , the error apeared in the PCM and all the pcm functions stop working !!!!
and when i got the error the NAV,phone and cd changer will keep not working too !!
i have stock audio system and no ipod or aftermarket amp and speakers
its weired and killing me .. the idea about running the car and the music ,phone , NAV etc all work fine , then suddenly everything stop working is very very bad !!
Old Jun 15, 2012 | 02:14 PM
bbywu's Avatar
Try clear in the PCM fault with PIWIS and see if it comes back. My guess is your PCM unit is faulty.
Old Jun 15, 2012 | 02:17 PM
ysfg35's Avatar
dealer did that by piwis but did not solve the issue , should i replace the pcm unit or i can just fix it ??
Old Jun 15, 2012 | 02:24 PM
bbywu's Avatar
Is your car still under warranty? I am only guessing at what the problem is. I would hate for you to spend money to replace the head unit only to have the problem not go away.
Old Jun 15, 2012 | 02:28 PM
ysfg35's Avatar
no its not i will go to an audio shop tomorrow , they may fix it , or i may switch to another audio system.
Old Jul 11, 2012 | 04:05 PM
ysfg35's Avatar
any one ??
, it seems that no audio shop can fix it .. look like nightmare
