clutch problem
Old Jun 23, 2012 | 05:40 PM
swtdds's Avatar
swtdds has a spectacular aura aboutswtdds has a spectacular aura about
clutch problem
I have a 2007 Switzer R911 with stage 3 clutch. I have a soft clutch that bottoms out...basically I have no clutch. This started after normal driving. Seems like a hydrolic problem??? What do you think? Thx
Old Jun 23, 2012 | 06:19 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Clutch accumulator - have that looked at
Old Jun 23, 2012 | 09:55 PM
zippsub9's Avatar
zippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud of
the accumulators and hydraulic slaves are only meant for stock pressure plate ratings. anything in addition will increase the wear rate as well on top of the already somewhat faulty setup.
Old Jun 28, 2012 | 01:51 PM
OneFasTT997's Avatar
OneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud of
That's odd. I have replaced 2 slaves on different Turbos and each time the clutch was harder not softer. Have you had it looked at yet?
Old Jun 28, 2012 | 04:01 PM
zippsub9's Avatar
If the accumulator goes it won't equalize pressure from the hydraulic pump on the rear and often blow out fluid at the weakest points...usually the o-ring seals in the pentosin lines. This also creates a hard pedal feel since the pressure from the accumulator is now working against the clutch master cylinder inside the slave. When the slave goes, you lose the assist from both typically creating a harder pedal feel in order to actuate the clutch fork.
Old Jun 28, 2012 | 06:30 PM
zippsub9's Avatar
What I meant to say about the accumulator is that when it goes bad, it seems to not release pressure and constantly holds built up pressure taking all the feel away from the pedal and becoming soft. I will be curious to see what the results are. Accumulators are 125 from Suncoast I believe.
Old Jun 28, 2012 | 08:38 PM
swtdds's Avatar
Car is in the shop now, Ruf (now RAC) in Dallas. I should know what the problem is tomorrow.
Old Jul 4, 2012 | 10:49 PM
Any update?
Old Jul 10, 2012 | 07:08 PM
swtdds's Avatar
Connector on the slave cylinder broke. Fixed for about $500
jaehoppa
Oct 22, 2015 09:17 PM
oo7
Sep 10, 2015 08:08 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
