Bad handling...
Old Jul 15, 2012 | 09:49 AM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Angry Bad handling...
Hi guys!
I took my 997 today, It's handling is really not good, while its Techart lower springs, GT3RS alignements and the PASM sport ON...
On track is it quite "correct" because the road is really proper, but on open roads or highways the car is "swinging" with the unperfections of the road, I hate that, even my M3 and my buddy's 997.1 4S with sport chassis handle better...
What is the solution? Sway bars (I don't think so...), new shocks? (my car is only 42000 km used) If yes, which ones would you prefer?
I often speed drive and track it, my TT is not my DD.
Ps: I plugged off my Mafs (run Proto tune) and I believe it is a bit better,a bit stronger, but my buddy still not gave me back my V-box, so I can't tell you more...
P
Old Jul 15, 2012 | 11:38 AM
spf4000's Avatar
spf4000 is a jewel in the roughspf4000 is a jewel in the roughspf4000 is a jewel in the roughspf4000 is a jewel in the rough
What do you mean exactly by swinging? Are you talking about tram lining? That's when your wheels feel like they are getting tugged around by the grooves on the road. If that is the case, that has more to do with your alignment. Aggressive camber and toe-out on the front will do that.
Camber/tow is a compromise between straight line stability (less camber, toe-in) vs. turn in responsiveness and cornering grip (more camber, toe-out). The fix would be to first see where your toe settings are and if it's pretty aggressive on the toe out, then bring that in a bit. If that doesn't help, then reduce the camber a bit and you should be good.
On another note, I'm not a fan of lowering springs. Get proper coilovers instead of lowering springs if you can. Makes a world of difference when spring rates are properly matched with dampener valving.
Old Jul 15, 2012 | 01:23 PM
K24F's Avatar
Thxs for interest,
I'm sure it is not tram lining, the car "dances" slowly and vertically on its wheels as if it was too smooth, I have to say I feel it during hard accels and high speeds when large curves.
The car runs straight, no problem, but does not feel as precise as I expect.
I have to say the car dynoed 675hp/900nm, perhap's time to think about chassis tuning?...
I bolted lower springs because I hoped getting the car stiffer and I prefer the look 1' lowered: nicer but same or worse than stock handling...
Old Jul 15, 2012 | 01:42 PM
bbywu's Avatar
Hard to judge whats happening based on your description.
Are you getting excessive squat and rear bias during your acceleration? Are you having oversteer problems on corner exit and difficulty with putting power down?
This could be because of insufficient rear spring rates for the power you are making. Oversteer on a corner exit is typically due to inadequate rear spring rates and excessive rear negative camber as you put the power down. Also, the overall sensation of "floating" could be due to insufficient spring rates over all, giving you excess vertical chassis movement, pitch and roll.
What type of aero do you have?
Old Jul 15, 2012 | 02:34 PM
K24F's Avatar
This description matches with my feeling, but I believe it is only the feeling anyone can have when hard driving a stock 997TT.
My aero is stock, only a Techart rear underfender but I do not believe it changes aero. (?)
Old Jul 15, 2012 | 02:39 PM
spf4000's Avatar
What he feels under hard acceleration is probably due to lack of traction, especially at 675HP. TADTS
As for the high speed cornering wandering, that could be due to a number of different scenarios: inadequate dampening, rear toe link bushing deflection, bump steer, etc. But he did mention that it was fine on a smooth track, which could mean that dampening, or the lack there of, is the culprit. I doubt it has anything to do with aero setup or else he would have felt it at the track.
Old Jul 16, 2012 | 09:28 AM
cannga's Avatar
IMHO what you are describing is a classic case of the ride vs. handling tradeoff in suspension setup. In general, a stiffly set-up car, whether by 1. springs, 2. damper, 3. tire, 4. sway bar, etc., handles better because of the reduction in weight transfer, whether front/back, or side to side (body roll). But what is the caveat? As the car become stiffer, at some point, it's going to start losing contract with road surface from road imperfections. This is why pro race cars are set up differently for different circuits (and what we cannot do): each track is setup for a perfect combination of stiffnes and road compliance.
More specifically to our Turbo, the first gen. PASM 1 in our Turbo has what is now considered a design flaw. PASM works by varying the dampening rate of the shock absorber; in the 997.1 Turbo, the normal setting has too soft of a dampening rate, and the stiff setting has sky high dampening rate. So the car pings and pongs between 2 states, neither perfect : normal setting is too soft causing a lot of body roll, and stiff setting is extremely jittery and is preserved only for glass smooth surface.
This is the origin of criticism from some press members of PASM ("we don't like this gimmick, just give us one good setting instead of 2 bad ones"), Porsche engineers admitted this at time of 997.2 release. Sport setting of PASM gen 2 is not nearly as stiff as PASM 1.
PASM is also fixed in Bilstein B16 coilover, either Damptronic or PSS10 version. With the Bilstein Damptronic, the 2 settings of dampening are very close to each other, so close that new users sometimes have a hard time telling if they are different!
So the one line answer is this: when dampening rate is too high, compliance goes down and tire loses contact if road is not perfect, your car "swings", another way of saying losing road contact/control. This is fact, "law of physics," so you cannot alter it, OTOH there are definitely a number of work-around's that you could try. IMHO:
1. Not use the stiff PASM setting when road is imperfect, and tunes the suspension (for example stiffens the suspension with drop links, stiffer tires, etc.) so that there is a good compromise for a majority of your driving. This is your case with Techart springs and I think it can be done successfully, now that I hope you recognize what you are dealing with.
2. Use the stiff setting all the times and softens the tire/other suspension components (not a good solution).
3. Changes the source of the problem, which is the damper/shock absorber, by using a coilover. Bilstein has two choices: non PASM coilover (Bilstein PSS10) or one with well-designed PASM (Bilstein Damptronic - without question a huge improvement over stock PASM).
Old Jul 16, 2012 | 12:27 PM
spf4000's Avatar
3. Changes the source of the problem, which is the damper/shock absorber, by using a coilover. Bilstein has two choices: non PASM coilover (Bilstein PSS10) or one with improved PASM (Bilstein Damptronic).
Minor correction. Dampening doesn't have an impact on the amount of body roll. The only things that change the amount of body roll are spring rates and anti roll bar stiffness. Stiffer shocks (specifically low speed compression dampening) just slow body roll.
Old Jul 16, 2012 | 12:57 PM
cannga's Avatar
Hi thanks for your input. I think I know what you're trying to stress: dampening is a time dependent parameter, that is designed primarily to control the oscillation of the spring. But IMHO yes dampening very much does affect the amount of body roll; we in fact have the very illustration of this in our Turbo. This is how PASM works!
PASM normal and stiff setting: which one has less body roll, the Sport setting or the Normal setting? The Sport setting right? What is the one and only difference between the 2 settings? The dampening rate.
I am not a physics major but I think another way of approaching this issue is assuming 2 extreme positions: dampening rate being zero, and dampening rate approaching infinity. In the case of infinity rate, the car will literally have no body rolll at all.
I think the explanation is in the fact that even though it is, as you said correctly, low speed compression, the low speed parameter itself is not one single value but is in fact variable - there are different "low speeds." Large radius freeway sweep is lower speed than sudden canyon double S curves, both being example of low speed compression. The higher the dampening the lower the "low speed compression" it will affect (I think, anyone please chime in as needed), until at infinity dampening where it does not allow any movement at all. I think I might be confused, and confusing. :-) Interesting discussion and good point.
Old Jul 16, 2012 | 01:45 PM
K24F's Avatar
Thxs guys for your answers
I believe my issue is the spring rate, too soft.
Even in straight line at high speeds the car balances from before to behind when the road presents large and smooth deformations, my 993TT does not (lowered too).
The 993TT is stiffer with low dampening efficience and the 997TT is too soft with efficient dampening, i believed bolting Techart springs could help but not, I'm now afraid I need the next step!
What about GT3 parts?
P.
Old Jul 16, 2012 | 02:24 PM
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
"low speed" refers to the speed of the shock absorber piston, not the speed of the car.
spf4000 is correct in that increasing dampening does not decrease body roll, it just decreases it over time. Sport or Normal, you will "eventually" roll the same amount. Sport is stiff enough to where in many transient events, you never actually experience the max body roll. But, in a long sweeper, in theory you would end up at the same roll angle - determined by the roll stiffness (springs and sway bars.)
Old Jul 16, 2012 | 03:28 PM
cannga's Avatar
Originally Posted by kitw
1. Sport or Normal, you will "eventually" roll the same amount. 2. Sport is stiff enough to where in many transient events, you never actually experience the max body roll. But, in a long sweeper, in theory you would end up at the same roll angle - determined by the roll stiffness (springs and sway bars.)
Are you not contradicting yourself between 1 and 2? FWIW I agree with 2 but not 1; in a quick right left right transient the car will NOT roll to the same degree between Sport and Normal. Test this for yourself.
Yes I think we all know it's the shaft velocity; I discussed and posted graphs for the PSS10 in the Bilstein thread. Perhaps there is a disagreement in term interpretation somewhere. Regardless, it is fact that varying the dampening rate is the basis of *all* adjustable systems, whether PSS9, PSS10, Damptronic, or whether Ferrari's rheomagnetic damper.
1. What do these systems do? Change the dampening rate.
2. What is the end result of changing the dampening rate? ....blank.....
The original point was "does it alter body roll amount." From driving these cars it is clear to me body roll is a major parameter that is affected when going from normal to sport mode in all of these systems, but I would also agree with "stiffness," "weight transfer." YMMV. It is for all of us to ponder what to fill in the blank above and that's why I think it's such an interesting discussion.
Old Jul 16, 2012 | 08:46 PM
997tttiplux's Avatar
997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute
Hello All
Mr. P, if you install Bilstein damptronic, don't settle the car too low otherwise the handling will be terrible (undriveable at high speed) for 2 reasons:
- altered geometry
- altered stroke of dampers
So I would advise to follow all the good readings here from Cannga, Alex_997TT and others and decide for yourself. Beware, some serious cash involved ;-)
David
airbusdrvr
Dec 27, 2015 07:43 PM
007 Vantage
Oct 8, 2015 08:35 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
DD GT3 RD
Sep 29, 2015 07:59 PM
