Upgraded VTG opinion please
Old Jan 20, 2013 | 06:12 AM
  #61
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Originally Posted by milou
Hello Nick, my best 60-130 was 5,8sec if i remember, it should be on the list :-)
Tiptronics are usually slower, faster only off the line, my car is also convertible which is more heavy
Tiptronics were slower when compairing the 996tt but the 997 model changed things I swear the stock times were faster?
Quoted from wikipedia!
"According to official Porsche figures, the 997 Turbo accelerates to 100 km/h (62 mph) in 3.9 seconds with the manual transmission, and 3.7 seconds with the Tiptronic S transmission."
Old Jan 20, 2013 | 06:25 AM
  #62
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I still believe that from 100-200 or 200-300 manual is faster
Old Jan 20, 2013 | 06:28 AM
  #63
GTRNICK's Avatar
Possibly but who knows without doing a few runs side by side!
Old Jan 20, 2013 | 06:43 AM
  #64
GTRNICK's Avatar
BTW what is the torque limit of the stock rods?
Old Jan 20, 2013 | 07:11 AM
  #65
DARTH-VADER's Avatar
DARTH-VADER is infamous around these parts
I believe 900nm torque max.
Old Jan 20, 2013 | 07:13 AM
  #66
milou's Avatar
My car makes 940nm on the dyno for 3 years now :-)
Old Jan 20, 2013 | 07:17 AM
  #67
GTRNICK's Avatar
Wow so the stock rods are pretty tough (and meant to be the weak link) if they can handle the best part of 680lbs/ft of torque
Old Jan 20, 2013 | 07:20 AM
  #68
Well there are bunch of cars with 3076/3071 with stock engines.
Old Jan 20, 2013 | 07:27 AM
  #69
GTRNICK's Avatar
Yes but is the torque limited or higher up the rev range?
HP doesnt seem to be much of an issue for the stock mezger lump does it?
Old Jan 20, 2013 | 07:53 AM
  #70
I think torque is limited because of stock rods with 3076 setup.
Torque comes with hp but after some hp torque just stops and you need more engine capacity ?
Old Jan 20, 2013 | 08:07 AM
  #71
GTRNICK's Avatar
Well you either need more capacity or stronger components to run more boost.
I think also with more capacity you run lower egt's I think!?
Old Jan 20, 2013 | 10:36 AM
  #72
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
It's all relative but stock rods are not that robust in my opinion. Anything larger than vtgs like 3071/3076, I would replace rods if you want max output. Even 68 mm vtgs are probably too much. If you don't want max output with A30s then save yourself some money and stay with vtgs. People with A30s who have been pounding their stock motors for a while probably have bent rods, they just don't know it. They are living on borrowed time.
Old Jan 20, 2013 | 10:42 AM
  #73
GTRNICK's Avatar
I have to agree with you and I think the same but I like to play advocate and see what people are doing!
It seems alot of people are running either race fuel or E85 or some sort of meth kit which would help alot!!!
I am interested in pump gas mods!!!!
What rods do you like or would go for? ( carillo, pauter what else? )
Old Jan 20, 2013 | 11:04 AM
  #74
TTdude's Avatar
With pump gas, just play it safe which is what others have said. One bad tank of gas can be detrimental if pushed too far.
As for rods, I think either Pauter or Carrillo are two main choices. Some would say Carrillo are stronger but I personally haven't seen any hard evidence about that. With Carrillo, you have to shave down the oil pump for clearance but that's no big deal because even with stock rods the oil pump is shaved (see pic below). With Pauter, no additional removal of material is necessary.
Old Jan 20, 2013 | 11:28 AM
  #75
GTRNICK's Avatar
Thats exactly what I have heard about the carillos that you have to do some extra shaving but thanks for the pic
As for pump gas I use shell v-power which is 99 ocatane and it is very good quality fuel also I am sure that the 997tt ecu is so sensitive that it will always look after the engine if no safety features are removed like some tuners do!!!!
Plus I have no intention of pushing my setup or future setups to the limit built engine or not.
