Stripped bolt head Exhaust Any Ideas?
Old Apr 14, 2013 | 06:54 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I am currently in the process of taking my old exhaust off. Got 3 of the 4 bolts out but have managed to strip the 13mm bolt head. DOes anyone have an idea how to get it out now?
Old Apr 14, 2013 | 06:59 PM
Nick-NY's Avatar
Nick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to beholdNick-NY is a splendid one to behold
slot it with a dremel then use a standard(flat head) screwdriver to un screw it. soak the bolt with penetrant.
Old Apr 14, 2013 | 07:06 PM
elite1's Avatar
Not sure that will work in this case. I dont think i could get enough torque on it with a flathead.
Old Apr 14, 2013 | 07:13 PM
bbywu's Avatar
Vice grip...or you could either try and drill it out using one of these if it is broken flush:
Is the bolt broken, or just stripped? If it is broken and flush, you could even remove the entire turbo and have a fabricator build up the nib with a TIG and then use a vice grip on it, after which, chase the threads.
One of the moderators (eclou) had the same problem:
https://www.6speedonline.com/forums/...pressions.html
Old Apr 14, 2013 | 07:18 PM
elite1's Avatar
Thanks for the ideas. Bolt isnt stripped thankfully. I tried vice grips and it still isnt moving.
Old Apr 14, 2013 | 07:21 PM
bbywu's Avatar
If you put some PB blaster on it tonight, you can try these tricks also...
Bolt extractor:
The Dremel trick would work, if you cut into the bolt, you can use an chisel and hammer to spin the bolt around.
Lastly, my personal favorite (but may not be applicable in your situation)
Drill a small hole in the center of the bolt, and hammer this in then use the vice grip.
Old Apr 14, 2013 | 07:29 PM
elite1's Avatar
Bolt head
Old Apr 14, 2013 | 07:33 PM
bbywu's Avatar
Bolt extractor socket.
I'd try hard not to destroy the nut unless last resort. But there is a tool to do it if necessary:
Old Apr 14, 2013 | 07:42 PM
Nick-NY's Avatar
soak the nut and threads with Wurth Rost-off and try the vice grips again. Make sure they are TIGHT. avoid needle nose ones as the length causes them to twist.
Old Apr 14, 2013 | 07:55 PM
elite1's Avatar
Got it with a large set of Vise grips. Now i will have to figure out where to get some new bolts. Thanks for both of your help with this. I soaked the bolt with WD-40 rust release spray.
Name:	Thank goodness.jpg
Old Apr 14, 2013 | 07:58 PM
bbywu's Avatar
Did the entire stud come out?
Old Apr 14, 2013 | 07:59 PM
elite1's Avatar
Yes the stud came with it.
Old Apr 14, 2013 | 08:08 PM
bbywu's Avatar
Good deal - I've seen them break inside the turbo.
Old Apr 14, 2013 | 08:18 PM
Nick-NY's Avatar
I'm glad you got it out without any issues.
The engine may smoke up a bit upon startup due to the WD-40 but it will burn off in a few minutes.
Old Apr 14, 2013 | 08:40 PM
elite1's Avatar
Thanks once again guys! I guess I gotlucky on this one.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
