Spark plugs and coil packs.
Old Jun 10, 2013 | 08:04 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
So what plugs do you guys run without misfire issues?
Also I wanted to get new coil packs so at the moment the choice is BBI or EVOMS what do you recommend?
Cheers,
Nick.
Old Jun 10, 2013 | 08:36 AM
XLR82XS's Avatar
Modified car? If so NGK BKR7E. BBI coils are great - I'm running OE 997 coils in my 996tt and they are operating fine.
Old Jun 10, 2013 | 09:37 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I've run and am running Denso PK20PR-P8. They seem to work well. I have BBI coils just installed but not had a chance to push it. So far, so good.
Old Jun 10, 2013 | 04:10 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
I'm running the same plugs but I'm not sure if they are what you want unless you are running a tuned ECU. I think they are colder than eom's. Best,
Old Jun 10, 2013 | 08:43 PM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
I am also running the P8 Densos. I think those are best used when you are modded though. I am almost at 7,000 miles since the 775kit was installed and I thought next year I would replace the plugs and coils - probably with the same ones I have now as they seem to work great and without issues.
Old Jun 11, 2013 | 06:41 AM
Bluecrab's Avatar
Bluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud ofBluecrab has much to be proud of
interesting topic, hope for more feedback.
I run stock software for now, but when I do replace my spark plugs I would be interested in using something that would be dual purpose if it exists. IE work with stock software, but also be useable with a tune...
Old Jun 11, 2013 | 07:54 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Cheers,
Nick.
Nick....we used stock plugs on every car we build.
On some of the larger displacement engines we've built running higher boost, we also used the BBI coilpacks for a stronger spark but STILL used the regular factory recommended plugs. So far they've held up to up to 30psi of boost and 850 HP at the wheels.
Old Jun 11, 2013 | 08:08 AM
Bluecrab's Avatar
thanks for the insight
what software do you use?
Old Jun 11, 2013 | 08:15 AM
Thumbs up
We use GIAC.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
MKIVdan
Nov 13, 2015 06:00 PM
bongnation
Sep 25, 2015 02:58 PM
jungt
Sep 16, 2015 05:28 AM
