Help Identifying Cable Behind Rear Lense
Old Jul 7, 2013 | 10:22 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
I replaced my brake light bulb on the rear driver's side (left rear when looking from behind) and when I removed the lens assembly to get to the bulb, I noticed the end of a thin cable wire underneath some sticky black tape. This was lying flat right behind where the lens assembly sits. I traced the wire to the center engine lid locking device. The wire is neatly routed through plastic fasteners and it looks stock. Could it be just the tail end of the wire cable after it was connected to the locking device? I looked in the owners manual and there is no reference for it. Additionally, when I changed the right side brake bulb last year, I did not see this cable or tape so it is only on the left side. Any thoughts on this? My car is bone stock witn no accidents. Thanks in advance for your thoughts on this...
Old Jul 7, 2013 | 10:42 PM
TT Surgeon's Avatar
Yes, that's the emergency cable to open the engine compartment, I believe there is another spot to access it on the right.
Old Jul 7, 2013 | 11:17 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Hi there, is the wire accessed through the wheel well fender, like the manual cable is for the front compartment ?
Old Jul 8, 2013 | 08:17 AM
jhbrennan's Avatar
Exactly what it is - I've pulled it and it works...but if you ever needed it how do you remove the tail light to get to it if the compartment cover is closed??
Old Jul 8, 2013 | 03:07 PM
997TTurbo's Avatar
Thanks for the info on this mystery cable. Amazing how the owner's manual doesn't mention it.
I have the same question that jhbrennan has: If you need to use it, how do you get to it?
The engine compartment lid has to be open to remove the light assembly and then the cable is right there. With the engine compartment lid closed, how do you get your hands on this cable? Underneath the car somehow? Reaching underneath the inner rear wheel well where the black plastic liner is?
Old Jul 8, 2013 | 07:05 PM
TT Surgeon's Avatar
I think you get at it under the bumper cover on the rt side.
Old Jul 8, 2013 | 09:38 PM
KK Moto's Avatar
KK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud ofKK Moto has much to be proud of
Assuming your battery is dead and you need to access the engine compartment:
Step 1: Insert Key into drivers door and open manually.
Step 2: Remove Fuse Panel door by dead pedal.
Step 3: Attached to fuse panel door is a thin but rigid wire with a hook (L-shape).
Step 4: Use wire to "fish" the emergency release out.
Step 5: Pull.
There is also an emergency Fuel Door release inside the passenger door.
There is also an emergency Bonnet release, similar to the trunk, but I do not remember where its at. Under the one of the headlights? It's not well publicized. Actually maybe that one in the passenger door is for the bonnet. I'll have to go yank on it.
Old Jul 8, 2013 | 09:51 PM
997TTurbo's Avatar
Great info from KK Moto. On step #4, where do you start fishing for the wire? Underneath the tail lense? Is there enough clearance to get in there and snag it?
Old Jul 9, 2013 | 06:45 AM
KK Moto's Avatar
Yes, the wire & the clearance is very small. IIRC it is under the drivers side tail light.
Just keep fishin, you'll catch it.
Old Jul 9, 2013 | 11:30 AM
997TTurbo's Avatar
Thanks KK Moto!
Goonie
Sep 13, 2015 02:26 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
