How to maintain GT2 seats
Old Aug 17, 2013 | 11:31 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
So after having the car a short time, I feel like I am beating the snot out of the leather on the thigh bolster when I am getting in and out of the car.
I push the seat back so I am not trying to squeeze in or out but I still feel like I am wearing it out bad.
So how do you get in? If there is no secret then how do you keep from wearing the leather to much? Or should I not worry about it and just replace the cover once it starts to wear badly?
Old Aug 17, 2013 | 11:32 AM
93ls1rx7's Avatar
and I am a fairly skinny dude so it isn't a "size" issue.
Old Aug 17, 2013 | 11:56 AM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
If you're referring to the carbon bucket seat (when I had my GT2) I would hold the steering wheel with both hands and put my right foot in the car and put my butt into the middle of the seat while avoiding the bolster and then slide my butt down. I had wear on mine and took it one of my patients who does upholstery for high end cars and was told to have fun with the car and when the bolster gets super bad just bring it in and have the outer piece replaced and have more cushion material added. Hope that helps.
Old Aug 17, 2013 | 12:01 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
I have the GT3 RS carbon seats so have a similar ingress/egress type of issue that you describe, and I'm not a small guy either.
I think drsullivan's technique is pretty good. I actually make it a point to be cautious due to not wanting to wear out the side bolsters, but I can also tell you that my car is fairly high mileage by normal standards (60k) and the side bolsters still look reasonably good. Best wishes!
Old Aug 17, 2013 | 02:05 PM
93ls1rx7's Avatar
drsullivan, yes the carbon bucket seat.
I guess I will keep being cautious and not worry if it wears a little.
Old Aug 17, 2013 | 06:03 PM
TT Surgeon's Avatar
Or sell them to me and not worry about it.....jk
We are going to need more pics though.
Old Aug 18, 2013 | 01:35 AM
93ls1rx7's Avatar
The car is at the detailer getting the tree sap removed...the previous owner used to park under a tree and it got pretty bad. We are planning on taking here out for a little photo shoot later today if the weather holds.
Old Aug 28, 2013 | 09:33 AM
Papasmurf188's Avatar
Papasmurf188 is infamous around these parts
I have been holding on to the steering wheel with my right and placing my left hand on the doorsill (not the paint) with the seats push all the way back. This allows me to get both legs over the side bolster but under the wheel most of the time. No my wife getting in the other side is a whole other process.
Old Aug 28, 2013 | 11:35 AM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
^+1 or you can see if the dude in this thread still sells the protectors.
https://www.6speedonline.com/forums/...rotectors.html
Old Aug 29, 2013 | 07:23 PM
Tuvok's Avatar
Tuvok is infamous around these parts
I bought the CF side bolster protectors from Sean ad they work great. I highly recommend them. They are made from alcantara and have an excellent fit and finish.
Old Aug 29, 2013 | 11:19 PM
Hey, many thanks for providing the information and link to the product made above. I just contacted him and am hopeful I can still purchase these.
Old Aug 29, 2013 | 11:37 PM
20C4S's Avatar
Seen Sean's protector. good stuff. but try not to sit on the bolster when u get in & out of the car. i move seat all the way to back like u do. the key is to use left hand on the door sill area to support the body weight so u're not rubbing against the seat.
Old Sep 1, 2013 | 09:09 AM
pwdrhound's Avatar
I have 996 GT3 Euro seats in my car and have absolutely zero wear on them. These seats are actually deeper and narrower than the GT2 seats. The trick to getting into them without touching the side bolsters if you are reasonably athletic is this:
1. Grab the steering wheel with your right hand
2. Put your right foot in the car with your heel on the floor just ahead of the pedals
3. Place your left hand towards the aft end of the door sill slightly behind your body
4. Now support the weight of your body with the planted heel of your right foot in the car, your left hand braced against the door sill, and your right hand pulling on the steering wheel. Your butt will now easily clear the side bolster without any contact as you settle into the seat as you raise your left leg and place it in the vehicle.
If you do it this way you will not get ANY wear and tear on the seats.
Old Sep 1, 2013 | 12:42 PM
93ls1rx7's Avatar
Tried it today and didn't feel the seat bolster at all....thanks all for the help.
I did feel like I was doing the hokie pokie.....put you left foot in, pull your left foot out....
Old Sep 1, 2013 | 10:11 PM
SBPORSCHE's Avatar
SBPORSCHE is infamous around these parts
When getting in I put my right hand onto the center hump between the two rear seats to brace myself as I get in.
On the way out I use the door sill for my left hand as a brace.
