IHRA Rules
Old Feb 21, 2014 | 05:47 PM
Casper 1's Avatar
Casper 1 is infamous around these parts
IHRA Rules
With new found power and a hankering to establish "official" numbers I took a look at the regulations as established by the IHRA and my local track (Palm Beach International Raceway) to confirm my compliance. I was disappointed to find a new (established 2012?) requirement as follows..........
• All cars 9.99 or quicker in 1/4 mile must have engine diaper plus an IHRA or IHRA license (engine diaper does not need to be certified).
• All Sport Compact cars 11.99 or quicker must have engine diaper
Based on the above and if I understand correctly, I must apply an engine diaper to both my Turbo S and GT2 as both will run quicker than 9.99 seconds.
Can any one with first hand experience confirm I must use an engine diaper if I run below 9.99 seconds?
Old Feb 21, 2014 | 05:51 PM
Casper 1's Avatar
If I do require a diaper any recommendations?
Old Feb 21, 2014 | 09:40 PM
Staff@WORLD's Avatar
Staff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to behold
They are very easy rules to become compliant with.
NHRA license requires a basic medical examination and 6 passes that are signed off by mother licensed driver. Three passes that are 1/2 track and 3 full passes. At that point you will have a license. The license should be good to 7.50.
As for the engine diaper, you can easily install a diaper that can easily be removed. They have diapers that install with straps.
Old Feb 21, 2014 | 11:29 PM
Casper 1's Avatar
Thank you! Three questions..................
1. Any idea if 911's are classified as "sport compacts"?
2. Have you seen an engine diaper for 911's? I see then for front engine V6 and V8's but nothing for our rear mounted 6's.
3. Have you had any luck mounting diapers on 911's?
Old Feb 23, 2014 | 10:21 AM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
I ran IHRA (Summit) drag racing events all last year. Granted I'm only in the 11's with my setup, but I passed all tech inspections and was never required to add a diaper. The only question that ever came up was that if I ran faster than 9.99 I would have to have a roll bar to pass tech.
Old Feb 23, 2014 | 11:46 AM
Casper 1's Avatar
Unfortunately, I have found it IS enforced. It will become apparent very quickly I am running below 9.99, I have no choice but to buy (and install) the daiper.
Old Feb 23, 2014 | 12:51 PM
32krazy!'s Avatar
have you run your car at the track yet? 9.99 isn't as easy as it seems
just doing a quick search on what exactly an engine diaper does it appears its purpose is to catch oil should a rod bust a hole in the oil pan. since the turbo motor is a dry sump and theres no oil pan and its a horizontal motor it doesn't seem needed. i would bet the ihra officials don't see many porsche motors at the track
Old Feb 23, 2014 | 02:45 PM
Casper 1's Avatar
I agree, getting into the 9's is not easy.
Havent brought the GT2 to the track however based on what I am seeing via my V-box I am very certain it will break into the 9's. The Turbo S, with less CMS upgrades, runs 9.87 in the quarter, I am very certain it will do well.
I only want to establish numbers for my own gratification and for CMS. I hope to represent the P-car crowd well at PBIR.
I hope they may consider a dry sump exclusion but doubt it.
Old Feb 23, 2014 | 02:59 PM
32krazy!'s Avatar
i have a friend that runs at pbir almost every weekend and his sport compact car runs 10.5 and i know he doesn't have any blankets. don't think it will be an issue
a bigger issue would a roll bar for 135 mph or faster and a chute for speeds in excess of 150 mph
Old Feb 24, 2014 | 05:22 AM
Casper 1's Avatar
I will let you know, I have been told once you break 9.99 they make sure you meet all rqmts. I have a helmet and the roll bar but not cushioned. I doubt i'll need a chute .
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
sdg1871
Nov 22, 2015 07:27 PM
rob4wellness
Oct 2, 2015 07:32 AM
