Engine has to come down what damage can I do
Old Apr 16, 2014 | 02:38 PM
swole305's Avatar
swole305 has a spectacular aura aboutswole305 has a spectacular aura aboutswole305 has a spectacular aura about
Talking Engine has to come down what damage can I do
Hey Guys - the engine in my turbo has to come down. What can I do for upgrades
Old Apr 16, 2014 | 02:43 PM
bmwtek's Avatar
bmwtek is a jewel in the roughbmwtek is a jewel in the roughbmwtek is a jewel in the roughbmwtek is a jewel in the rough
search function /endthread
Old Apr 16, 2014 | 03:04 PM
swole305's Avatar
Thanks for killing my fun. I know there is a search function but destroys the conversation. Oh well.
Old Apr 16, 2014 | 03:27 PM
deaddana's Avatar
deaddana is infamous around these parts
Good place to start looking
Try the marketplace on this forum, someone was selling the electric opening exhaust, sorry i dont remember the name, im a noob. Thats pretty cool. Any preventive maintanance? Good time to detail the engine and bay. Bumpers gotta come off , right? Who says the same one has gotta be put back on?
Old Apr 16, 2014 | 03:28 PM
SamboTT@ByDesign's Avatar
Enjoy the ride.
Why is motor out?
Old Apr 16, 2014 | 04:06 PM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Injectors for an E85 tune!
-Mitch
Old Apr 16, 2014 | 07:07 PM
Forujames's Avatar
Forujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to all
new plugs and CF inlet pipes. (what's the problem?)
Old Apr 16, 2014 | 07:14 PM
swole305's Avatar
I was driving the car, hard of course, and the cooliant sensor went off. At first I was worried but then watched the gauge. Then the temp spiked pulled over and water was steaming and cooliant leaking on the ground. It seems that the water pump might be cracked. All the hoses look good but where the water spray and stains are they need to drop the engine to further figure the issue and fix the problem.
So a little bit of pain for the repairs but a whole a lot of fund for mods.
Old Apr 16, 2014 | 07:36 PM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
It is unlikely that your water pump is bad. Most likely you have a coolant fitting that pulled out. Common unfortunately.
If engine is coming down you should do basic maintenance. Replace the fuel filter, change the plugs, pin the coolant pipes or get the aluminum ones and have them TIG'd in place (like I am sure you are doing since the motor is coming out for this). Should consider replacing the water pump. Fun stuff would include injectors so you can run an E85 tune in the future. If you want to do that, you'll need a clutch which is easy with the motor and trans out of the car. Finally, you could think about doing turbo inlet pipes, but they are very expensive and not worth it unless you are changing turbos (or going absolutely all out on the stockers) as well.
Another mod that will serve you will with your .1 turbo is upgrading to the .2 intercoolers. They are a fraction of the price of the aftermarket units and nobody has proven with actual data that they are worth 2,3, 4x the price of the OEM units.
Old Apr 16, 2014 | 07:41 PM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
if you are changing your clutch, do the GT2 slave conversion as well. With the upgraded clutch, the stock ones are bound to fail.
Old Apr 16, 2014 | 09:42 PM
kenromero's Avatar
kenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond repute
Here is your opportunity to change the injectors!!! Have you had it mapped? If not, injectors, mapping and perhaps inlet pipes. I.C., plenum, Y-tube, throttle body can be done with engine installed.
Old Apr 17, 2014 | 01:32 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
E85 injectors, Connecting Rods, upgrade coolant fitting, GT2 Slave conversion and new clutch
Old Apr 17, 2014 | 04:25 AM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
I second A418, most likely the coolant fitting just came out. Plenty of threads on that here. Don't put motor back in without addressing that. I has same issue and I had mine pinned. All is well now.
Sayajin
20
Oct 7, 2019 09:13 AM
ECS Tuning - VW
Aug 28, 2015 11:10 AM
ECS Tuning - VW
Aug 27, 2015 01:37 PM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
