Batt help
Old Aug 9, 2014 | 11:07 PM
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
Batt help
I've realized that Porsche batt are not the best...does anyone know what the batt weight is and if there's anything better lighter then the interstate mph7 I'm looking at....jeez 49 pounds is heavy...
Old Aug 10, 2014 | 06:27 AM
jhbrennan's Avatar
One extreme - very expensive though
http://www.suncoastparts.com/product//LITHIUM.html
You could also try the Optima Red Top but you'll need a special tray to mount it properly - look here:
http://www.yellowdogmotorsports.com/details.php?id=104
One more - special mounting needed also
http://www.braillebattery.com/index....ightweight_agm
Old Aug 10, 2014 | 07:57 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Just be careful taking the old one out. The angle that you have won't be optimal for your back trying to lift 50 lbs out of there.
I wonder if the frunk would be okay for someone to stand in. If yes, that would be perfect for getting the best leverage
Old Aug 10, 2014 | 07:58 AM
jhbrennan's Avatar
I'm 200 lbs and it holds me just fine. Done it at least 3 times in the last 7 years.
Old Aug 10, 2014 | 08:23 AM
Would anyone have a confirmed weight on Porsche oem batt...
Old Aug 10, 2014 | 08:25 AM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
That's U$81.00/lb saved!
Cheaper to go under the knife for liposuction :P
Old Aug 10, 2014 | 08:27 AM
I've called interstate and they said the h7 is direct replacement
Old Aug 10, 2014 | 08:51 AM
jhbrennan's Avatar
Looks like you'll have to weigh yours after you remove it. I've never seen an actual number but only reports of 50 to 52 lbs.
Old Aug 10, 2014 | 08:56 AM
Jako's Avatar
That sounds right. For standard batteries that offer 650 CCA and over, which the oem porsche battery is 780. The weight is typically 50lbs.
niceguy
May 31, 2013 02:39 PM
ciaka
Cayenne 955/957
Jan 8, 2013 08:15 AM
steve harris
Mar 12, 2009 05:16 PM
