SRF Overkill
Old Sep 16, 2015 | 07:01 AM
Alankey's Avatar
Alankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant future
SRF Overkill
I have PCCB's and only do road use and service the car every 2 years as per schedule.
Would SRF brake fluid be overkill for road use? I read that it needs to be changed annually and doesn't necessarily match the other fluids. Any one using it on here?
Old Sep 16, 2015 | 08:25 AM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
SRF will outlast other high-performance brake fluids due to its low hygroscopic nature / high wet boiling point. If only for the street, changing it every 2 years is no problem. If you are tracking, you can get away with once a year (depending) whereas with other brake fluids (Motul, ATE, etc.) you really should change them after every event or two.
Summary -- yes, it is overkill for the street but isn't much more costly than other high-perf brake fluid. It will last making it cost effective.
Fadi
Aug 17, 2018 05:16 PM
Feelgood MD
Mar 24, 2016 09:35 AM
sideboob
Sep 24, 2015 05:09 AM
plastique999
Track & Autocross
May 22, 2009 09:47 PM
Cannonball996
Nov 12, 2008 12:11 PM
