Another Round of mods (rods and goodies)
Old Dec 2, 2015 | 09:19 AM
  #31
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
heads are going. been trying to knock out one cyl per night after work. Here are some rough in, to 80% complete (final sanding not complete until all 24 ports are measured and reasonably the same).
This is a very mild port, focusing on the normal pinch points.
Old Dec 15, 2015 | 12:33 PM
  #32
Thanks to an awesome jig from SRM I have the 12mm conversion half way done.
Old Dec 15, 2015 | 08:22 PM
  #33
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
WOOT WOOT!!
Let me know if you have any questions, looks like ur doing just fine!
Old Dec 15, 2015 | 10:35 PM
  #34
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Originally Posted by itguy
WOOT WOOT!!
How does the jig work?
Old Dec 15, 2015 | 11:09 PM
  #35
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Pilot holes with a built in sleeve for the drill?
Old Dec 16, 2015 | 01:41 AM
  #36
itguy's Avatar
This was sour prototype, inserts remain the same, from right to left, locating pin, drill bushing, tap bushing, drill bushing (2)
We still recommend having the liner case and heads drilled on a bridgeport for accuracy but the case part is very easy with this tool.
Old Dec 21, 2015 | 02:41 PM
  #37
Yup.. my cylinders/heads done on a bridgeport.. cases with this jig.
Old Dec 30, 2015 | 07:52 PM
  #38
Rods baby!
Also test fit one of the 12mm studs
Old Dec 31, 2015 | 06:15 AM
  #39
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
How are you planning for the final rod assembly especially the hated center cylinder?
Old Jan 3, 2016 | 06:10 PM
  #40
Not sure. It came apart easily so I am hoping/assuming I can get it back together
Old Jan 3, 2016 | 06:28 PM
  #41
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
I'll be posting a step by step 2 weeks from now when I re assemble my bottom end. There is an order for it to be done.
Old Jan 4, 2016 | 04:06 PM
  #42
VR- thanks.. ya i knew it was a challenge, just didnt know how much of one!
If there are any references out there, please post.. thanks. Going to try to mess with it a little tonight.. maybe
Old Jan 4, 2016 | 07:12 PM
  #43
oldbooster's Avatar
oldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to all
I like the direction in this build. Good luck and looking forward to your updates. Please don't go quiet on us when its complete!
For me its either going all out with displacement or do just the very basics like this which carries the least cost and risk of all options. Anything in between to me personally is meh as then it just adds up very quickly and you end up wishing you did more while you were in there at least it does/would in my case.
Old Jan 7, 2016 | 09:39 AM
  #44
yeah center cylinder can be a pita, easy to mess the rings up. i dont recommend doing while tired
#TeamAIM
Old Jan 7, 2016 | 10:48 AM
  #45
Rhonda@FVD's Avatar
Premium Sponsor
Rhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond repute
Just to let everyone know we also sell the rings separately if you need them.
They are our part # 100 103 102 01
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
