Another Round of mods (rods and goodies)
Old Jan 23, 2016 | 03:25 PM
  #61
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
BTW, We'll see how others pan out. I may have just had some bad luck, but I am not super happy with how square the studs are. Visually they are square, but you can measure that they are not. Looking into it. Ill have a delay while I have to disassemble the heads and open the holes to 1/2".
Anybody know of any 997.1 engine cases around if I decide to redo it :-/
Old Jan 23, 2016 | 04:36 PM
  #62
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Thanks for calling Jordan, you should be all set, no need for a new case
Old Jan 23, 2016 | 04:45 PM
  #63
Engineering brain got the better of me. Ha
Old Jan 30, 2016 | 05:27 PM
  #64
cylinders/heads are on.. w00t. (pics soon)
What are you guys using to seal the cam/lifter "plates".? Manual says drei bond 2210.. gotta be something I can get local.... thanks!
Old Jan 30, 2016 | 05:41 PM
  #65
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Porsche lists their "goo". I don't know why they didn't use rubber gaskets with stainless inserts where the bolts tighten? Would make sense on a high end engine. I'm tempted to use clear silicone...... But.... It's not easy to fix a small leak once the engine is in. My suggestion, but the goo.
Old Jan 30, 2016 | 06:07 PM
  #66
The special goo is usually just an off the shelf rebranded stuff. I mean, at the end of the day.. all engines are SO close to the same in this regard.. alum/alum, similar temps and chem resistant requirements.. *shrug*.
I need a refresher tho:
In that pic.. is the black thing a gasket? I am 99% sure it is, but it didnt come in my gasket kit
Old Jan 30, 2016 | 06:28 PM
  #67
vr6tee's Avatar
Yes, that is a gasket. I remember them from the removal .... Weird it didn't come I your kit, I haven't seen mine yet to know if they are there.
Silicone is a very universal high temp sealant, I'd imagine it would work perfectly as it does on very other engine in the world, but..... I don't know what the Porsche sealant costs, but the thought of a small oil leak does not excite me ... I'll buy their inflated priced sealant just to know it's not the sealants fault If I have a leak.
Old Feb 4, 2016 | 12:26 PM
  #68
Thanks to Sean @ Silly Rabbit Motorsports and Sam @ EVOMS for all the help along the way.
Waiting on cams and I think we will be on the home stretch.
getting there. Need cams!
Old Feb 4, 2016 | 12:35 PM
  #69
awesome.
r u gonna keep that pulley on ? i think i will go with the evoms one when i pull the motor.
#TeamAIM
Old Feb 4, 2016 | 12:45 PM
  #70
SamboTT@ByDesign's Avatar
Awesome Jordan!
Old Feb 4, 2016 | 04:13 PM
  #71
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
Originally Posted by prodigymb
awesome.
+1.. On pulley bigger contact surface and holds more power... I would reconsider the on from evo...
Old Feb 4, 2016 | 04:17 PM
  #72
32krazy!'s Avatar
the evoms pulley is smaller in diameter to slow the accesories down. its also press fit for a slight but more sturdiness. that being said the bbi or proto pulley works as well as evoms
Old Feb 4, 2016 | 04:44 PM
  #73
[QUOTE=32krazy!;4467065]the evoms pulley is smaller in diameter to slow the accesories down. its also press fit for a slight but more sturdiness. that being said the bbi or proto pulley works as well as evoms[/QUOTE...bigger contact surface on the crack for pulley to hold on to...I believe the evo is a better built unit....
Old Feb 4, 2016 | 04:49 PM
  #74
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Nice build,
At this power level you guys should consider a harmonic damper type pulley ... There is one custom made for our engines by ATI ..
Good luck and keep up the good work ...
Old Feb 4, 2016 | 05:37 PM
  #75
itguy's Avatar
Originally Posted by TT.BRN
Nice build,
Can you substantiate this with any technical information, or is this just a "I read it on the internet" recommendation?
