Steering wheel swap from 991.2TT to 997
Old Jul 17, 2025 | 02:19 PM
  #226
Audionut's Avatar
Audionut
I have a manual transmission 997.1 C4s with multi function steering wheel that I want to retrofit with a 991.2 steering wheel. If i wont be using the Multifunction button do i still need the GPS adaptor and steering column module 997.613.289.01 for the 991.2 steering wheel to work or its just a straight forward swap?
Old Jan 20, 2026 | 02:44 AM
  #227
AmmarHarris's Avatar
AmmarHarris
A 991.2 Turbo wheel might fit on a 997 column physically, but it won’t bolt straight up and won’t work plug‑and‑play without an adapter/clock‑spring solution and likely some wiring changes. Earlier 997.2 wheels work because the airbag/controls are the same generation, but the 991.2 is newer tech. You’d need:
• A 991.2 → 997 steering boss/adapter
• Modified clock spring/squib connections
• Wiring for buttons/controls to match the 997 BCM
It’s doable with custom wiring and adapters, but not a simple swap. If someone’s done it, it’s usually a fully customized install.
StogieSquid
Cayenne 955/957
Dec 8, 2020 09:50 AM
skandalis447
Mar 4, 2016 08:04 AM
fastm3
Feb 24, 2013 11:06 PM
SVTHorsnake
Apr 1, 2011 08:13 PM
