Keep blowing throttle body coupler off !
Guys, who has a solution for stock y pipe to throttle body coupler ? I keep blowing mine off, both clamps just slide off and the throttle body doesn't have a lip to grab onto. I even tried t bolts and they are too wide and come off also at 22psi. I am running stock y pipe and larger TB but still stock accordion looking coupler with the metal rings on it.
Anxious to hear this since it keeps happening to me at worst times, during track events. Have heard recommendations for hair spray, but trying to understand how to do that in such tight area.
Evolution motorsports does have a solution for this. But if you don't want to go there yet the best thing to do is clean everything with brake cleaner or carb cleaner. Make sure all surfaces are lubrication free. You would be surprised what is saturated on the surfaces. Then make sure clamps are aligned perfectly. Sometimes it feels like it's OK but the bottom edge may be a little off and it just walks off. Once you've done all this you can also use some hairspray on the surfaces to sort of make them stick but it won't be permanent. Feel free to give me a buzz during the week and I can help you with it. It's a pain in the *** for sure!
I upgraded to a larger clamp (wider than the stock one) when mine finally snapped when I was tightening it the last time it popped off.. So far so good, but I've got a stock y pipe and TB and max of 21 psi.
Good luck.
DC
This is it, clamps just walk themselves off. The tbolt one also since they are too wide and hang off the edge
ok so i scrubbed all surfaces with MAF cleaner, amazing how much oil is on everything. Then i took my sweet time aligning the tbolt clamps. All good for now, made about a dozen runs and its holding right now. I also removed the metal o rings on the stock coupler. Trick is also not too overtighten the tbolts as that just forces them to start sliding.
awb1455
Apr 30, 2016 06:13 PM
brnrdtns
Apr 10, 2016 09:04 AM
Wheel Dynamics
Apr 7, 2016 09:08 PM
