18 wheel
Old Sep 1, 2016 | 09:33 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
18 wheel
Thinking about buying a cheap 18" wheel for my occasion trip to the track.
Any recommendations? Dont care about weight. plan to use them 1x to 2 x a year, so no need for $$$
997, WB fitment. Rear only.
18x11 probably with a 305 DR.
Old Sep 2, 2016 | 12:49 AM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Why not 18x12?
With your application, you need more rubber on the strip/track. Maybe a 51 offset with a 315/30/18 tire?
If you're molding, maybe larger?
Old Sep 2, 2016 | 02:13 AM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
I would go with OZ wheels. Light and cheap! Best of luck bud!
Old Sep 2, 2016 | 02:14 AM
yumaverick's Avatar
Originally Posted by elite1
Why not 18x12?
You dont want to stretch a radial tire more than suggested. It prevents it from doing what it was intended to do!
Old Sep 2, 2016 | 01:08 PM
32krazy!'s Avatar
Why not 18x12?
for drag applications the taller sidewall is actually more important than the width. a taller sidewall allows for more flex and the ability to run a lower pressure for more hook. rubber band sidewalls just dont work at the track
Old Sep 2, 2016 | 11:37 PM
crgf1k's Avatar
crgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to all
I have these 18x12" OZ Challenge wheels, no spacers.
Old Sep 4, 2016 | 08:24 AM
pwdrhound's Avatar
18" are the best choice from a performance standpoint as they have more sidewall than 19s.
I run 18x10 with 275/35/18 and 18x13 with 335/30/18 NT01s. Fronts are 25.4" and rears are 26.0" tall which gives you a 0.6" delta making it safe for AWD set ups on the 7TT
Old Sep 5, 2016 | 11:02 AM
Thanks for the input. I like the taller sidewall.. also easier on drivetrain parts. (in theory)
Old Sep 7, 2016 | 08:05 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
That looks great!
What shop did you get your wheels from? Do you have any more pictures? I would PM you but PM's are disabled for you!
mep1811
Cayenne 958
Mar 30, 2016 08:08 AM
shifter_
Mar 29, 2016 10:48 AM
pdxm5
Mar 28, 2016 02:48 PM
Polar993
Mar 24, 2016 01:04 PM
tsweat
Nov 12, 2010 11:37 AM
