997.1 Lightweight Flywheel
Old Nov 15, 2016 | 02:50 PM
superslow's Avatar
superslow is infamous around these parts
About to do the clutch, I drive the car mostly for fun (never daily) and occasionally on the track.
Does anyone use or have a flywheel preference?
Old Nov 15, 2016 | 03:14 PM
kchu221's Avatar
kchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond repute
Ive seen alot of the members here use the Aasco flywheel or even the gt3 4.0 flywheel
Old Nov 15, 2016 | 07:34 PM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
Originally Posted by kchu221
gt3 4.0 flywheel
I run this with a RSR 4.0 clutch and Guard LSD .... track DE days and weekend car...
Love the combo .... clutch is amazing, revs quickly and the sound of the LWFW is so cool
Old Nov 15, 2016 | 08:53 PM
SamboTT@ByDesign's Avatar
If you don't mind a little chatter it's cool. With a nicely breathing set up and tune the car will rev nicely. But you do get some noise at idle and it's a little trickier in tight situations but that doesn't seen like it will be an issue for you. There are a few ways to get it done. Feel free to hit me up if I can help you in anyway or get you special pricing.
Old Nov 16, 2016 | 03:55 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Its a great mod to do, easier to rev match and a much "revvier" engine. Maybe try a car with one first to see if it's for you.
The 4.0/2RS flywheel is a good 4lbs lighter than the 964 flywheel, other than chatter the only issue is the ocational stall on deceleration, the car adapts to it but you might need to adapt your driving too (it does not like slow downshifts).
If you do go with one remember to get a sprung clutch disk.
Good luck
Old Nov 23, 2016 | 08:41 PM
Paintballzen's Avatar
Paintballzen is a glorious beacon of lightPaintballzen is a glorious beacon of lightPaintballzen is a glorious beacon of lightPaintballzen is a glorious beacon of lightPaintballzen is a glorious beacon of light
Sam set me up with the 4.0 LWFW combo.
i love it and would never go back. The throttle is much more responsive now and my shifting is actually smoother now.
My particular car has no chatter unless I flog it and heat it up a bit. Then you'll hear the slightest chatter at idle. YMMV.
All in all, I think it's a great upgrade.
Old Nov 23, 2016 | 10:34 PM
pwdrhound's Avatar
Good luck
964RS flywheel weighs 11.0 lbs, 996Cup/2RS flywheel weighs 8.2lbs. That's a difference of 2.8lbs. The 6Cup flywheel has slightly less surface area as the friction surface is narrower due to the machining.. You need a tune that accounts for the LWFW and you won't have any issues with drivability.
Old Nov 24, 2016 | 12:31 AM
TimeTomorrow's Avatar
TimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to behold
Not sure which setup I've got but the chatter is annoying. Definitely not "slight" by any means.
I also have never had the car stall, but you need to pay a little bit more attention when starting from a stop, which is kinda annoying when you are just tooling around, but when you are focused on your driving is fine.
Old Nov 29, 2016 | 10:50 AM
997TTEQNY's Avatar
997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future
Have a LWFW in mine.
Not a fan so far. Issues with stalling and the chatter is BEYOND annoying.
Will be coming out next year.
