Motor trend reports 7:40 at the ring
Old Feb 7, 2006 | 10:59 AM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
They ran it on cup tires which is kind of BS but..... Thought this car would beat a ZO6 out of the box, now I don't think it will.
Old Feb 7, 2006 | 12:05 PM
HotRodGuy's Avatar
still impressive!!
Old Feb 7, 2006 | 12:22 PM
SD1's Avatar
SD1
Oh yeah definetly. I think the new GT3 and or the GT2 will beat it.
Old Feb 7, 2006 | 12:29 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Did GM ever state what kind of tires the C6Z had when it set it's Ring time?
Old Feb 7, 2006 | 01:14 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
How fast did the Z06 go around the 'Ring?
Old Feb 7, 2006 | 01:32 PM
20C4S's Avatar
60k less. u can lose that in Vegas in about 5 sec.
SD1's Avatar
SD1
7:42 on the OEM Goodyear runflats.
Old Feb 7, 2006 | 02:37 PM
I think it was 7:43
And where did GM state the time was accomplished with runflats? The last article I saw said GM experimented with several different tire set ups prior to the recorded time, and they never said what the final tire configuration was.
Old Feb 7, 2006 | 02:47 PM
NAPO's Avatar
NAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to behold
You guys need to give Porsche some credit! The 996 GT2 did the Ring in 7:46 and the old 996TT did it in 7:56... The 997TT will do atleast a tenth of a second faster than the 996 GT2 without the cup tires. That's a HUGE improvement! Kudos to Porsche!
Let us compare this to the Ferrari F430... The old 360 Challenge Stradale did the ring in 7:56 (which is a sad time, considering the non-X50 996TT without the X73 suspension, gets that time) and the new F430 does it in 7:55... That's a pathetic improvement!
Yea.... PORSCHE RULES ALL!
Old Feb 7, 2006 | 03:29 PM
Originally Posted by NAPO
You guys need to give Porsche some credit! ...the old 996TT did it in 7:56...
And don't forget that the 7:56 was with 415 hp on the OEM stock suspension. Add both X50 and X73 and the 996 Turbo would probably be in the low 7:50 to high 7:40 range.
Old Feb 7, 2006 | 03:36 PM
HotRodGuy's Avatar
I think the only true fair comparison for the F car would bet to compare the 360 NON-CS to the 430, then the 360CS to the 430CS when it arrives
Old Feb 7, 2006 | 04:41 PM
SD1's Avatar
SD1
You are right, the time was 7:42.99 so 7:43 is the number, maybe I drank the kool-aid on the tires, I posted on corvetteforum to see if someone can actually verify that it was on the runflats.
Old Feb 7, 2006 | 05:08 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
They said in the magazine that they have to try different type of tires before they did the run for the Z06..
Old Feb 7, 2006 | 05:33 PM
SD1's Avatar
SD1
I can't confirm it other than to say some (respected) corvettforum members are saying that it was running the stock tires.
Old Feb 7, 2006 | 05:47 PM
variable's Avatar
variable is infamous around these parts
Wish they hadn't used cup tires... it doesn't give us any kind of accurate comparison.
