About 07 997TT fault code p0021
Old Jun 22, 2018 | 11:13 PM
gybmw's Avatar
gybmw is infamous around these partsgybmw is infamous around these parts
Hello, I have a 997TT that came to the United States in 2007. It has 46800km in Taiwan. At present, it is checked that the engine lights up with the fault code p0021. The fault code cannot be deleted, but the vehicle is not moving any differently. It is very doubtful. Do you request advanced help? Can share any experience or solution is currently very helpless Thank you
Old Jun 23, 2018 | 09:14 AM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
If you do some googling you will find information about this code. It has to do with the variocams on the car, and could be different things, with a great variance in cost to repair.
As will all things, your best bet is to go from least expensive to most expensive solutions and the way to gather that information is to research the issue.
To get you started, look at this thread:
https://www.6speedonline.com/forums/...cel-p0021.html
I have read a variety of posts about this issue, it can be a serious issue and should be addressed.
Good luck!
Ed
Old Jun 24, 2018 | 09:21 AM
gybmw's Avatar
Thank you, after reading all the articles
I am very worried that my 997TT is due to the rotation of the camshaft This question I have contacted Porsche technicians in Taiwan
Hope to have good news,
God bless!
Old Jun 24, 2018 | 11:30 AM
lliejk's Avatar
5 Year Member
Here is another thread from another site with at ton of posts about this issue. Again, it goes from replacing a controller external on the engine to pulling the engine to "pin" the cams.
https://rennlist.com/forums/997-turb...-camshaft.html
Also, remember it may be the electronics controlling the variocams, which is much less expensive. Typically swapping units from left to right tells you whether the problem is with the control unit or elsewhere.
Ed
Old Jun 25, 2018 | 08:05 PM
gybmw's Avatar
Thank you for your suggestion Porsche technicians have already aligned the solenoid valve and the camshaft sensor before checking the camshaft. I get the same result. I will ask the technician to test the actuator again.
Old Jun 25, 2018 | 09:35 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Good luck with it ,here's my experience with it.
https://www.6speedonline.com/forums/...yone-else.html
Old Jun 26, 2018 | 11:16 AM
lliejk's Avatar
5 Year Member
Yes, but make sure they swap right and left and see if the code stays on the same bank or moves with the actuator.
Based on what you have already done, you may still be looking at Cams, but it is worth the effort.
Ed
Old Jun 28, 2018 | 09:31 AM
gybmw's Avatar
My camshaft has been removed and I am very sure that my car engine light is on fault code P0021.
The real cause is that the internal shaft of the camshaft is completely blocked.
Old Jun 28, 2018 | 09:34 AM
gybmw's Avatar
Old Jun 28, 2018 | 03:57 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Horrible to see ... Thanx for taking the first clear pictures showing this issue ... Rep to you...
A few pointers:
- Do the other side while you're in there. Porsche shop will mot do it, take it to a machine shop let them fix and pin both intake cams.
- You'll need new cam bolts and a little friction washer for the intake cams, if they reuse old harware the timing might not set properly
- At this point all the "While in there" maintenance work is just parts cost.
(Plugs/coils/w.pump/coolant leaks/belt/clutch ect.)
Good luck ..
Old Jul 2, 2018 | 09:59 AM
gybmw's Avatar
My car removed the other intake camshaft today, but it didn't have the same problem as the second column. Its oil passage position is correct, which is why I am very confused? Does a friend know why? ?
Old Jul 2, 2018 | 03:29 PM
lliejk's Avatar
5 Year Member
If you mean that one bank (one side of the engine) had the problem and the other did not, that is NOT unusual.
However you should get BOTH pinned while you are there.
Ed
Old Jul 4, 2018 | 03:16 AM
mrkout's Avatar
mrkout is infamous around these parts
I had the same issue with my 2007 TT with 80, 000 kilometer. Except than i was able to rease the code. But it kept on coming up every few months.
So finally i decided to address the issue. Instead of fixing/pinning the cams, i ordered Schrick billet cams. Then i said while im on it, lets do the heads as well. Heads got CNCed with bigget valves and stronger springs. Then i said, why not do better rods as well since engine is apart. And i kept on adding parts on and on till I reached around 30K in bills until i got partially satisfied
Old Jul 4, 2018 | 02:23 PM
Dguth's Avatar
5 Year Member
Dguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of light
Beware of the while you are in there bug!! I'm living proof but I've got a one of a kind awesome build.
Old Jul 4, 2018 | 02:29 PM
mrkout's Avatar
Lol.
Prior to my porsche, I had a corvette. It all started with a simple air intake and tune, and ended with a 1000hp twin turbo stroker engine with fully built drivetrain hhhhhhhhhh.
Then i swore to the wife that it will be the last car i modify. Fast forwarding alittle bit, my porsche now pushes around 850whp lol.
