997TT aluminum water pipe off problem
Old Jul 17, 2018 | 09:20 AM
gybmw's Avatar
gybmw is infamous around these partsgybmw is infamous around these parts
997TT Aluminium water pipe shedding problem Re-fixed welding is completed! !
Old Jul 27, 2018 | 02:27 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Increase your argon gas flow rate....your welds shouldnt have that black stuff around them
Old Jul 27, 2018 | 04:02 PM
08957's Avatar
08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute
Did you consider to pin them instead of welding them?
Old Jul 28, 2018 | 08:44 AM
gybmw's Avatar
[QUOTE = 08957; 4729870]?你有沒有考慮到管腳他們,而不是將它們焊接的[/ QUOTE]
Hello, do you have a better way to fix this aluminum tube?
Can you share your picture or method?
Thank you!
Old Aug 1, 2018 | 02:49 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
There are a bunch of different posts with varying amounts of information, but their seems to be 3 lines of thought on this repair:
1. De-glue, clean up and re-glue
2. De-glue, clean up and re-glue AND pin by drilling a hole in the outside housing and into the fitting, cut a thread in the outside housing and run a screw (of appropriate dimensions) to engage the fitting and prevent it from being ejected from the housing
3. De-glue, clean up and weld
I have yet to see a detailed write up on the exact procedure for pinning, but that is the way I am leaning when I tackle the project.
Ed
Old Aug 2, 2018 | 09:40 AM
gybmw's Avatar
The following image is another fixed way I found on the Internet recently. Is this method feasible?
Old Aug 2, 2018 | 11:49 AM
lliejk's Avatar
5 Year Member
Looks cool, but that is beyond my garage mechanic's tools or capabilities.
I am pretty certain I can do re-glue and pinning, but this looks like you would need something special to cut those threads.
Ed
Old Aug 2, 2018 | 02:11 PM
turboslut's Avatar
Ed
BBI provides the welding service...
search BBI coolant pipe retrofit on Google
ECS Tuning - VW
Feb 9, 2016 12:27 PM
ECS Tuning - VW
Nov 16, 2015 03:22 PM
Armytrix_F1_Exhaust
Aug 11, 2014 03:01 AM
REDNOSEGT
Bentley
Dec 25, 2012 08:50 AM
