Help with codes, Car fell flat on its face pedal not responsive
Old Aug 26, 2018 | 02:52 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
I was out all day yesterday and driving the car normally then at one point I decided to get on it and the car fell flat on its face, just like when I used to hit fuel/boost cut from overboosting in my older toyota days but the gas pedal was not responsive.
Difference between this and when I hit boost cut in past on other cars is that stepping on the gas didn't move tach. I pulled over quickly shut off and restarted, check engine light came on, I gave it a little gas then when I started moving same thing happened, falls flat on face and gas pedal wasn't working. Each time I tried to restart, the idle was rough and a few times it shut off.
After multiple attempts to get it going I waited about 10 minutes, gave it another go and it started and stayed idle. I rev'ed it out and it felt smooth so I decided to try to make it to my uncle's house who was a few minutes away.
It stayed on but when I got to my uncle's house I tried to take it around the block, gas worked but absolutely 0 boost as if a boost hose came off but when I looked underneath everything was in place.
I stayed there for a couple of hours to let the car cool down before I made an attempt to get home. Although check engine stayed on it made it home no problem. I drove slow and tried not to press the pedal too hard until I got home, then when I was a few minutes from home I stepped a little harder and could see a little boost on the gauge this time.
When I got home I pulled out the durametric and below are the codes:
P1554 - Malfunctioning throttle,
P1266 - fuel cut (I guess the car went into safe mode)
P0121 throttle position sensor and
P1095 which I guess because of bad MAF reading errors relative to throttle.
Has anyone experienced this? Car is stock, no tune exhaust or mods.
It appears to be a bad throttle position sensor and is this sensor on the gas pedal or Throttle body or do I need to change both?
Thanks in advance for your feedback
Old Aug 26, 2018 | 05:51 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
That happened to me once when I left the pressure sensor on the y pipe disconnected. Didn't check codes though. Just plugged it back in and it was fine. Not saying that's the problem because like you I would look at the tps.
Old Aug 27, 2018 | 11:42 AM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
MAF?
Loose hose connection not obvious from a visual?
An electrical connection related to throttle position/MAF/boost?
The suddenness of it sounds like a boost leak to me, but I could be wrong.
Ed
Old Aug 27, 2018 | 11:49 AM
YJosephTT's Avatar
Originally Posted by lliejk
MAF?
Ed
Thanks, I don't think its a boost leak or a popped off hose because after 2 hrs the car ran fine and made boost like normal.
If the hose popped off, it would keep the same symptoms.
I also replaced the MAFs last month but I unplugged and re-plugged the connectors when It happened, I also thought about bad MAFs or bad connection also.
Codes point to changing the Throttle Valve assembly since I can't just replace the TPS.
Gonna order one today $235 on Pelican.
Old Aug 28, 2018 | 01:58 PM
964hans's Avatar
964hans is infamous around these parts
Hello @YJosephTT.
In the attachment you will find some info about E-Throttle
Regards
Hans
File Type: pdf
Old Aug 28, 2018 | 04:04 PM
YJosephTT's Avatar
Originally Posted by 964hans
Hello @YJosephTT.
Regards
Hans
Thank you much for this.
Old Sep 19, 2018 | 03:00 PM
YJosephTT's Avatar
Just wanted to update on this past issue of no Throttle response, the readings I believe were false and triggered from overheated ecu.
I changed the Throttle valve assembly and the pedal just to be safe and the same thing happened again.
This time when I noticed it starting to act funny again and logged it with durametric.
What I could see from durametric was the pedal potentiometers were responding when I stepped on gas but the pedal value, actual plate values and throttle plate potentiometers didn't change.
What was in common with previous times was the car had been running for a while and was hot. Oil and coolant temperatures were fine but the car was idling and/or in traffic when it would begin. I got the feeling that this is heat related and not an issue with actual Throttle valves, possibly a bad connection but somehow relaed to heat.
So I went to pull the ecu and check the connectors to the harness and it was very clear the entire rear firewall area by the ecu was extremely hot.
The ECU was also very hot to the touch. I unplugged the battery and removed the ecu.
I let car cool then reconnected everything but left the ecu downside up and exposed and removed the rear padding over the rear where the ecu sits.
Since then I've been driving the car this way trying to get it to replicate the problem and its been driving smooth. Even sat in traffic almost hour and no more problems.
It seems like the ecu was overheated and causing it to glitch out.
So far I can't get it to come back, but ecu is still exposed in the back.
I plan to send it to Marski to check what kind of tune might have been on it.
I suspect maybe the car had a tune once and reverted back to a bad stock base tune before I got it.
I'll update as more along the way.
Old Sep 19, 2018 | 06:06 PM
lliejk's Avatar
5 Year Member
Wow, great diligence in finding this. I had no idea the ECU could get cooked by the engine heat.
Ed
VID997
Sep 24, 2018 03:08 PM
TAch Miami
Site News & Feedback
Jun 3, 2013 09:48 PM
dmoney
Apr 27, 2009 01:56 AM
dmoney
May 14, 2008 07:47 PM
