E85 flex fuel capability
Old Jan 20, 2019 | 10:24 AM
Bookshelf's Avatar
Bookshelf is infamous around these parts
I’m guessing there is no way to have flex fuel capability with the stock ECU? What are the options as far as aftermarket ecu’s? I know there is ProEFI, we have been running e85 for 10 years in my brother’s Supra. I would like to have flex fuel capability due to E85 around here being anywhere from 70-85%. Thanks
Old Jan 20, 2019 | 03:57 PM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Syvecs is an option.
ESmotor installed it on my car.
Also AIM performance did quite few E85 997.1
​tuned by Emre at ESmotor
Old Jan 21, 2019 | 10:10 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
There's been no confirmation that the stock ECU is not capable of flex fuel with the appropriate code/ROM development done to enable such a function, but that fact remains that the market for it is very, very small (and therefore unlikely to happen). Grab an AccessPort and flash back and forth between the two is the best mobile option right now short of going standalone.
Old Jan 21, 2019 | 10:19 AM
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
on e85, my range is about 160 miles per full tank. For a long drive I was able to fit two 5 gallon fuel jugs into the front trunk. Realistically you won't be switching around fuel types often enough to need flex fuel, and you shouldn't tune for the ragged edge of ethanol content anyway. Buy a fuel test kit and figure out which local gas station has the highest ethanol content fuel and use that:
Amazon Amazon
Old Jan 22, 2019 | 08:00 AM
Syvecs has flexfuel capability.- that is what I use in my car. I don't see Flexfuel coming to stock ECU any time soon even though it is possible with this ECU.
#TeamAIM
Old Jan 22, 2019 | 11:07 AM
Bookshelf's Avatar
Is anyone using proEFI on here?
Old Jan 23, 2019 | 07:38 AM
o7silverturbo's Avatar
o7silverturbo is infamous around these parts
Dont bother with proEFI thats old news.
Im running the syvecs flex fuel is great since you dont have to worry about switch between tunes like with the cobb
Old Jan 23, 2019 | 07:45 AM
using mine as a paperweight.
#TeamAIM
Old Jan 23, 2019 | 09:04 AM
Bookshelf's Avatar
What makes ProEFI bad on a Porsche?
Old Jan 25, 2019 | 08:16 AM
jhbrennan's Avatar
I think it's E85 that's "bad" not the ProEFI - engine wasn't designed to run E85 on a regular basis. I wouldn't buy a 997 that has run E85...but that's just me.
Old Jan 25, 2019 | 08:28 AM
nothing bad or wrong with using E85 in this engine.
#TeamAIM
Old Jan 25, 2019 | 09:25 AM
e85 doesnt hurt the engine at all. Just have to make sure its tuned for it
Old Jan 25, 2019 | 09:26 AM
Bookshelf's Avatar
We went from running race gas to E85 in the Supra 10 years ago and have had zero problems. The E85 is used up and the car gets put away with 93 every winter. Haven’t had any problems with ProEFI either, and use traction control, anti lag, flex fuel etc
Old Feb 2, 2019 | 02:30 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Nothing basically bad with the ProEfi, its one of few ems out there that actually is fully can integrated, its the goto for LS swaps into 996/997 cars for a reason, in the hands of a capable tuner it will do everything you need and more. But, unless you get it for a bargain there is no reason to go with it (or AEM's infinity) if buying new, the syvecs is just a better bang2buck deal ...
Some details:
New, a basic Proefi PnP setup would run 4-4.5K$ .. Basic 112 setup no flexfuel or hd coils, this kit only logs with a laptop, 1K$ for their screen to log into a usb! Same with AEM basic setup harness and ems is 4.5K$ without any sensors.
Now, a basic S6+ runs around 4.5K$ too (S6/harness/noid/fuelp/map/egt's), you dont need too many extra sensors since it runs on all stock sensors, and it logs all the time internally (not an option) for upto 8hrs ... Faster processor, better support, its just a better system on paper and in reality ...
Cheers
mike2016
Mar 24, 2014 11:01 AM
kwak12r
Detailing
Jun 22, 2011 09:40 AM
ColorChange
Apr 28, 2005 10:16 AM
