Rough Idle
Old Jul 28, 2020 | 07:16 PM
krysFly's Avatar
krysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant future
Rough Idle
08 TT. Idles on the lower side, occasionally shuts down. I looked at different causes, i.e. fuel pump, vacuum leak.
Also at around 3K RPMS, sometimes the RPMS drop a bit, other than that it runs great, although there is a whistling sound which led me to believe its a vacuum leak.
Any suggestions would be appreciated
Old Jul 29, 2020 | 01:32 AM
964hans's Avatar
964hans is infamous around these parts
Hi,
Could be the camshaft positioner. Read the DME error messages to find out which bank.
You can swap left and right positioner (are the same) and read error messages once again. If failure swaps from one bank to the other you know its the positioner.
Regards
Hans
Old Jul 29, 2020 | 07:46 AM
krysFly's Avatar
Originally Posted by 964hans
Hi,
Regards
Hans
Thanks for the reply Hans.
I dont get any error messages, which is somewhat strange
Would it be the same cause if no errors show?
Old Jul 29, 2020 | 12:09 PM
964hans's Avatar
OK that's strange
I got error code P0021 (Intake camshaft positioner bank 2) and P2279 (Intake air system leak)
Old Jul 30, 2020 | 06:59 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
try cleaning your oxygen sensors as well.
Old Jul 31, 2020 | 01:30 AM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Depends when it's "whistling". At cold start the air pumps might be whistling, that's pretty normal if it's stock. Not sure why Hans is trying to talk about his error codes, doesn't seem to apply to you.
Poor idle is probably either a vacuum leak as you suspect - if you have the stock center plenum check the connections on the back. One of the nipples may have cracked off. Also if you're running an oiled aftermarket oil filter the mass airflow sensors (MAFs) may be unhappy, and that would definitely cause idle problems.
Old Jul 31, 2020 | 02:34 AM
964hans's Avatar
Smile
[QUOTE=Not sure why Hans is trying to talk about his error codes, doesn't seem to apply to you.[/QUOTE]
Only for (probably unnecessary) information
Old Aug 2, 2020 | 09:36 PM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
My idle issue was MAF2. I started with a pressure test, then logged some values, then got a 5 point security bit set, removed 1 MAF at a time, cleaned with a MAF spray and on the second cleaning the idle smoothed out.
If you can log values that may help.
YMMV.
Ed
Old Aug 3, 2020 | 01:56 AM
rix's Avatar
rix
Hit or miss there in my experience, over oiled air filters tend to make MAFs unhappy.
Old Aug 11, 2020 | 08:22 AM
lliejk's Avatar
5 Year Member
The other test would be a pressure test. While not fixing my idle drop problem, I did find a rubber elbow to the turbo actuators that had a split. I think it would be a good initial step for you.
Ed
ULSTRUP
Bentley
23
Apr 23, 2017 07:27 PM
CayenneS2083
Nov 29, 2013 11:44 AM
johnspeed
Sep 1, 2011 09:14 AM
ldc
Sep 14, 2008 06:23 AM
996x50
Oct 14, 2005 03:06 PM
