Tinted + light bulb changed
Old Aug 2, 2006 | 11:10 AM
997hk's Avatar
997hk is infamous around these parts
just changed the 6k light bulbs + the white fog light
still thinking about the wheels....techart? gemballa?
Old Aug 2, 2006 | 11:56 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
nice looking TT. Set of black Techart Formula will mtch your balck out look!
Old Aug 2, 2006 | 12:06 PM
Hussain's Avatar
Hussain is just really niceHussain is just really niceHussain is just really niceHussain is just really nice
what percent tint is that?
Old Aug 2, 2006 | 01:03 PM
fredttx50's Avatar
fredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond repute
that is hot!!!! May I ask where you got those so I can order a set for myself!
thanks!
fred
Old Aug 2, 2006 | 01:19 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Exclamation
what you have to do is now is buy a 6000k 50w H11 HID kit for your high beams and a 6000k 50w H8 HID kit for your fog lights. (i'm not sure if the fog-lights are H8 on the turbo, i know they are on the C4S)
http://www.xenonexpert.com/xteckit50w_combo.html
Old Aug 2, 2006 | 08:13 PM
997hk's Avatar
the headlight i used philips 6K HID and the fog light is H3 by philips as well. Tried to change the LED ones but the warning lights turn on on dash so i cant do it for now. the tinited is by 3M so not sure the percentage.
cheer!
Old Aug 2, 2006 | 08:16 PM
split's Avatar
Exclamation
LEDs are usually dimmer than halogens anyway (not per watt of course)
if you want to remove that dash-warning light you have to wire a load resistor in parallel to the LED to reduce the resistance. For example, the circuit is expecting 5ohm of resistance or something, so you have to put a 6ohm resistor parralel to the LEDs so it brings the total resistance of the circuit down to 5ohm so it will think that a regular halogen bulb is there and working. You have to get the resistance just right or the car will think something is wrong.
Old Aug 18, 2006 | 05:41 PM
gmoney's Avatar
www.hoen-usa.com
H3 for turbo, H8 for rest of 997. Compatible with bulb failure warning system, same power as stock.
Old Aug 19, 2006 | 10:33 AM
Zlaatan's Avatar
Zlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant future
Get the Gemballa Racing black edition in 20"!! Same as the Gemballa Avalanche, looks stunning!
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
vchris
Cayenne 955/957
Aug 25, 2015 05:37 AM
metzkaro
Aug 24, 2015 02:59 PM
