Bridgestone tires on nmy new 997TT
Old Dec 10, 2006 | 11:56 PM
peter salvatore's Avatar
peter salvatore is infamous around these parts
My 997TT was delivered today to the dealership. While it was still wrapped I noticed it had Bridgestones versus the Michelins I expected and had on my 997S. Should I be concerned? Do I have any option to ask the dealer to change them out for the Michelins? Are they as good?
Regards,
Peter
Old Dec 11, 2006 | 06:35 AM
Tony007's Avatar
Tony007 is a glorious beacon of lightTony007 is a glorious beacon of lightTony007 is a glorious beacon of lightTony007 is a glorious beacon of lightTony007 is a glorious beacon of lightTony007 is a glorious beacon of light
I received Bridgestones too. Initially I too wanted them swaped out for Michelins. I've got about 200-300 miles on them so far and noticed they really stick like glue. I'm not concerned about switching tires any longer. Give them a try I think you will like them.
Old Dec 11, 2006 | 06:48 AM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
Mine was a launch car, came with PS2s.
Old Dec 11, 2006 | 08:36 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
No problems here with the Bridgestones. I was just unhappy to learn the rears weigh 34lbs each vs 29lbs for the PS2's. Of course they also cost 40% less
Old Dec 11, 2006 | 10:12 AM
Many reviews I have read say they are stickier. Yes the weight is one of the reasons I wanted the Michelins also......particularly since I have the ceramic brakes to save on weight.
Thanks for your responses!
Peter
Old Dec 11, 2006 | 02:54 PM
masterlu's Avatar
masterlu is infamous around these parts
Many dealers will put whatever tires you want on your new Turbo.
Old Dec 11, 2006 | 02:56 PM
6088TTS's Avatar
6088TTS has a spectacular aura about6088TTS has a spectacular aura about6088TTS has a spectacular aura about
the new Bridgestone RE050 are great tires... even my 738tq SL65 hooked well on them...
Old Dec 12, 2006 | 11:44 PM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
FYI, there are the lesser RE050As and then there are RE050A Pole Positions which are essentially "S-04s".
It's the latter that you want and per Damon @ Tirerack, the last time i checked like three weeks ago, the Pole Positions are being sold at introductory pricing right now. they will be priced similary as the PS2s at some time in the near future. could be wrong here so check your tire sources.
RE050A PPs are comparable to PS2s except they are non directional so you can swap them side to side for those of us who like to run a bit of neg camber for a bit more bite in the turns.
i'm loving them so far on my ride
PS - bridgestone even offers a tire a cut above the PS2/RE050PP level with the RE01Rs or something like that so check that out
Old Dec 13, 2006 | 09:04 AM
Thanks for your response but according to Tire Rack the " New Pole Position" is still not available in the 305X30x19 in the Porsche OE N spec tire
Peter
Old Dec 13, 2006 | 09:43 AM
Tony007's Avatar
I was at the dealer yesterday and borrowed a tape measure to compare the rear tire contact patch between the 305/30/19 PS2's and the 305/30/19 Bridgestones on my 997TT.
Surprisingly enough I measured the PS2's "worn in" contact patch at 10.75" exactly. The "worn in" contact patch on my Bridgestones measured 11.5" exactly.
Thought this was rather interesting. It just might suggest the PS2's is a better handling tire for the track and the Bridgestones are a better staight line tire for drag strip "hook up duty".
Watcha think?
Old Dec 15, 2006 | 01:49 AM
tony, without mentioning what kind of tires the bridgeys are, it makes it all the more difficult to make any sort of determination which is better than the other.
peter, i'd hit up damon at tirerack to get an idea of ETA if ever for the RE050A PPs.
All I know is, the PS2s and the RE050A PPs are comparable
Old Dec 15, 2006 | 09:09 AM
Tony007's Avatar
The Bridgestones that came OEM equipped were the RE050A's.
Old Dec 15, 2006 | 05:33 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Mine came with the PS2's which I would certainly prefer over the a's....The pole positions are comparable though....
Lou
PV=nRT.
Sep 9, 2022 06:06 PM
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
