Does anyone else have this PROBLEM???
Old Nov 14, 2007 | 01:58 PM
schicago's Avatar
schicago is infamous around these parts
4th gear grinds when cold, first is tempramental.
Old Nov 14, 2007 | 08:19 PM
thuggy's Avatar
thuggy has a spectacular aura aboutthuggy has a spectacular aura about
1st and 2nd gears are different synchros than the rest I believe. Hence the different behavior while cold. Its normal.
Old Nov 14, 2007 | 10:15 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Synchronizers work best when warm.
Ferrari's have a 2nd gear engaging prob when cold and I'll frequently go from 1st to 3rd until the car warms.
Once toasty warm, shifts beautifully.
Lots of oil to fully warm.
You might also want to drain the gearbox and use Redline transmission oils. It makes a big difference in mine.
Old Nov 14, 2007 | 10:28 PM
lig's Avatar
lig
lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !
^^^ I was wondering if going to a synoil would improve the action.
Mine has zero issues with 3+ when cold. Just a reluctance to go into 1st and 2nd.
Jay - I still have a soft spot for the E46 M3. Not a fan of the Bangleized bimmers though.
The funny thing about the 997 is that it's got so much more grunt than the S2000 that I really don't feel the need to shift super quickly.
Old Nov 16, 2007 | 06:19 PM
levrac68's Avatar
levrac68 is infamous around these parts
Thanks for all the info. The seperate synchros makes a lot of sense. I'm going to change the fluid, I believe that should make a big difference. I'll keep you posted on how it works out.
T
Old Nov 16, 2007 | 06:30 PM
Gcalo's Avatar
Originally Posted by levrac68
--- I'm going to change the fluid, I believe that should make a big difference. I'll keep you posted on how it works out.
T
This will make a noticeable difference.
All too often transmission and read end fluids stay in for the car's life. Big mistake.
Go to Redline and guaranteed you'll notice a difference.
Old Nov 16, 2007 | 07:24 PM
planenuts4speed's Avatar
planenuts4speed is infamous around these parts
Originally Posted by tsmithmdtx
For me it is 1st gear that is notchy and sometimes almost impossible to engage when cold. Seems like others have similar experiences and it is just part of owning a Porsche.
Me too!
Old Nov 16, 2007 | 08:38 PM
tBaker's Avatar
tBaker is infamous around these parts
I find that getting back into first gear tough, but 3rd-6th is like butter.
Old Nov 18, 2007 | 06:22 PM
krusher's Avatar
krusher is infamous around these parts
I had a unique situation, two 997C2s within a month> the first was a flood total after 2500 miles. The second was almost a clone. The first car shifted smoothly in all six gears. The second car is rough from first to second. Reminded me of my old "62 Vette with non syncro 1st gear. I just assume that all six gears have syncronizers.
Old Nov 18, 2007 | 07:36 PM
Gcalo's Avatar
Originally Posted by krusher
---The first car shifted smoothly in all six gears. The second car is rough from first to second. Reminded me of my old "62 Vette with non syncro 1st gear. I just assume that all six gears have syncronizers.
Gear oil, gentlemen, gear oil.
Get it changed out asap with redline and you'll see a big difference. After a few thousand miles change it again to flush out all the older oil.
Yes all 6 gears do have synchros.
Old Nov 18, 2007 | 08:25 PM
Pacific 911's Avatar
Pacific 911 is infamous around these parts
At one point it was nearly impossible to get into reverse and hard into first; the dealer adjusted the linkage and it is better. Apparently Porsche's subconscious attempt to bring back the 915 transmission.
cockneymike
Oct 22, 2015 06:00 PM
Zero911
Sep 24, 2015 06:33 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
