Dension 500 Bluetooth Help!
Old Feb 10, 2010 | 06:20 PM
drkside's Avatar
drkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to all
I have the Dension 500 installed with the Bluetooth addition. I have having an issue with call quality when I use the bluetooth in my car. The microphone is clipped to the sun-visor, so there should not be a problem picking up my voice. Any time I use the system to answer or make a call the person on the other end of the phone has a VERY hard time hearing and understand me. Anyone have this issue with their Dension Bluetooth? Any advice for a fix or an improvement? Getting very frustrated....
Old Feb 10, 2010 | 07:10 PM
rated_m's Avatar
rated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of light
Did you try adjusting the mic or speaker volume of the BTA1500?
Old Feb 10, 2010 | 09:04 PM
drkside's Avatar
no, how is that done?
Old Feb 10, 2010 | 09:07 PM
rated_m's Avatar
Here is link to the instructions.
http://dension.com/index.php?pageID=13&articleID=99
Old Feb 10, 2010 | 09:11 PM
drkside's Avatar
Thanks I will give it a try. Looks like I also need to download the firmware
Old Feb 10, 2010 | 09:18 PM
rated_m's Avatar
Depending on when you bought the unit, you might not have too. It worked for me right out of the box and I got mine at the end of November. Use the PCM to input the digits, push the send button above the number pad and wait, in about 5 to 10 seconds the digits disappears and it is set.
Good luck.
Old Feb 11, 2010 | 10:26 PM
drkside's Avatar
push the send button above the number pad? I don't see a send button on my PCM....
Old Feb 12, 2010 | 04:35 PM
phil_m's Avatar
phil_m is infamous around these parts
where can we find the bt1500 firmware? I usually go to bumperplugs, and I have the latest firmware for the gw500.
Old Feb 12, 2010 | 09:18 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Read this, then click the link in the article:
http://dension.com/index.php?pageID=13&articleID=58
You're welcome
CATTMAN
Old Feb 12, 2010 | 09:35 PM
phil_m's Avatar
Thx for the link cattman. I tried the files but maybe my bta1500 is too old. When I try and dial the ***12 code, it actually does dial on my phone as opposed to just changing a setting in the system.
Old Feb 13, 2010 | 06:49 AM
Cattman's Avatar
The next logical step would be to contact Dension's helpdesk. They'll get back to you in a day or two, and will likely as for a pic of your unit and bar code. If it's an old unit, they may send you a new one.
CATTMAN
Old Feb 5, 2025 | 10:43 AM
jarek's Avatar
jarek
i have the same problem
have you fixed it?
jabed92694
Apr 3, 2016 11:31 AM
Perkman87
Nov 19, 2015 05:31 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
nephew
Sep 30, 2015 06:57 AM
