intermittent smart top funtionality
Old Aug 8, 2010 | 08:45 AM
mfm3's Avatar
mfm3 is infamous around these parts
I recently installed a SmartTop on a '06. I've noticed the additional functionality (windows, top, key fob operation) of the SmartTop is working intermittently. It worked fine after the install but now on some days the top and windows function as if the SmartTop was not installed. Anyone else experience this or have ideas about what the problem may be?
Old Aug 8, 2010 | 10:01 AM
dma550's Avatar
dma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond reputedma550 has a reputation beyond repute
I find that you need to be very close to make the full functionality work from the fob.
Another thought is that maybe you're not fully seated back there? It was a little tricky getting the header and pins to "lock".
Old Aug 8, 2010 | 10:12 AM
doug2255's Avatar
doug2255 has a spectacular aura aboutdoug2255 has a spectacular aura about
I agree. Initially I thought the battery might be getting low in the fob, but either way, mine works fine from a closer range.
Old Aug 8, 2010 | 10:23 PM
WaltB's Avatar
WaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond repute
Same here. Try closer.
Old Aug 9, 2010 | 06:33 PM
mfm3's Avatar
The issue is not so much the functionality with the key fob, but I do appreciate the advice regarding proximity. The problem is more related to normal SmartTop functionality. For example, my wife just came home, hit the top switch once and the top started to close, but when the top up cycle was done, the rear quarter windows were only half way up. It is these kinds of glitches that have me scratching my head.
Old Aug 9, 2010 | 08:33 PM
WaltB's Avatar
In that case I would recommend you disconnect the module and reconnect it. Then ensure it is secured properly and will not come loose. You may have a connection problem.
Old Aug 10, 2010 | 07:06 AM
raspritz's Avatar
raspritz is infamous around these partsraspritz is infamous around these parts
Actually, I have the same issues and have been in touch with the manufacturer. The problem has not been resolved, as it is intermittent. I suspect there has been a bad batch of SmartTops.
Old Aug 10, 2010 | 07:24 AM
dma550's Avatar
Mine always works great from the console. The remote is a 50/50 shot. Usually when I try to be cool and have the car opened up for my lady, it sticks half way and looks like a transformer whose battery died.
BLKMGK
May 31, 2016 04:32 AM
BLKMGK
Sep 19, 2015 03:51 PM
carsnob
Sep 8, 2015 04:10 PM
Fester
Sep 8, 2015 09:35 AM
Nuke
Sep 8, 2015 09:09 AM
