Tire Help
Old Aug 18, 2010 | 09:04 AM
CMartin348's Avatar
CMartin348 is infamous around these parts
Tire Help
I need some help determining tire size, type and season! I've done searches on here and read a lot on Pirelli PZero vs. PS2 and I think I'm going to try the PZeros this time.
I live in Nashville, TN. We don't get snow and it's usually not below 45 degrees in the winter. Do you think I can get away with using summer tires year round? Or is it worth the extra money for winter tires?
Also I have an '09 C4S Cab with 19" Carrera Classic Wheels and 5mm Spacers. What tire size do I need, front and rear?
Thanks in advance!
Casey
Old Aug 18, 2010 | 09:33 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
I used to live in Nashvegas too...summer tires are fine. You should get the same stock size that came on the C4S
235-35-19 front
305-30-19 rear
33psi cold front
39 psi cold rear
Have the car aligned too....! Makes a huge difference in tire wear....make toe to minimum specs around .02 to zero degrees front and no more than .16 degrees rear...try for .12 degrees but not less than that and at least -.8 camber front and no more than -1.3 camber rear. Have your guy dial in each side to perfection. This will work great for the street and spirited drives.
Old Aug 18, 2010 | 09:56 AM
exponential's Avatar
exponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to behold
Still prefer PS2. Longer life, PS2 still running well and quiet after 20,000 miles
Old Aug 18, 2010 | 02:25 PM
CMartin348's Avatar
235-35-19 front
305-30-19 rear
33psi cold front
39 psi cold rear
Thank you! I have no idea what any of the second part means but I'll just show it to the tech. haha
Old Aug 18, 2010 | 10:19 PM
96redLT4's Avatar
96redLT4 is infamous around these parts96redLT4 is infamous around these parts
I'm just getting ready to replace my back tires P Zeros with 14.3K miles on the clock. They were the original and I think about $50 cheaper per tire than PS2
Jim
Old Aug 18, 2010 | 10:22 PM
mdrums's Avatar
Tech will understand....if you track your car you could dial in more camber but a stock 997 with PASM will have max camber at around -1 degrees away.
Old Aug 18, 2010 | 11:37 PM
Vegas's Avatar
Vegas is a splendid one to beholdVegas is a splendid one to beholdVegas is a splendid one to beholdVegas is a splendid one to beholdVegas is a splendid one to beholdVegas is a splendid one to behold
My car came stock with the PS2's and now I have the Bridgestone RE050A's and I love them. If you haven't already decided, throw these into the mix. They're good.
Old Aug 19, 2010 | 01:03 AM
NorthVan's Avatar
Summer tires are good to temperatures as low as 45F/7C
Old Aug 20, 2010 | 01:36 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
+1.
Never met a Pirelli that I liked.
Old Aug 20, 2010 | 02:37 PM
LeNoah's Avatar
LeNoah is infamous around these parts
Everyone needs to be aware that there are NEW PZeros. They are N2 rated. They have been getting good reviews so I just put on a set. Too early to tell if I'll be happy with them but at about $350 less than PS2's it was worth a shot.
So far I haven't put 'em to the test yet so we'll see.
I too had the OLD PZeros on a previous Carrera and did not like them. Switched to PS2's and was much happier. But the reviews I've seen on the NEW PZero's along with the price delta convinced me to give 'em a try. I'll report more after I have a few miles on them. We're looking at a HWY 1 to Monterey run next month so that should be a good opportunity to feel them out.
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
