Idiot needs help...
I replaced the steering wheel and airbag on my 997.2 MT (plain wheel) today. The airbag didn't just "click" into place, like I have jammed it into the wheel. The springs that hold it in place are apparently (best I can see) engaged, but releasing them does not "spring" the airbag housing forward to grasp hold of it. The best part...wait for it....
The horn is stuck in ON position.
I am feeling pretty violated.
Any suggestions that don't involve taking it to the stealership, like how you get the airbag out of the hub?
Other than mentioning that an airbag is like a hand grenade and I prefer to let well-insured mechanics fiddle with them... No, I can't think of anything else to say.
Gary
Personally I would not be messing w an airbag that might need to deploy properly one day. I am sure you will get all kinds warnings if it is not in right. While I respect your frugality, go to the dealer, do not pass go......and do not let an idiot work on your car.
once you've said that, there's not much more you could possibly add. thanks.
Usually I appreciate the sarcasm, but fyi--the horn does not blast unless the ignition is on.
You probably figured this out already, but the problem is almost always the flat wire that goes to the airbag. Gotta put the airbag in perfectly straight and make sure that the flat cable stays in the little depression for it, on the right side.
Love all the useless responses here. sounds like you already figured it out, but hopefully this will help the next guy, as this seems to pop up at least once every couple of months (and it happened to me, too.)
Well, that saved your battery anyway.
Gary, P.S. Since you scorn my sarcasm, can I just say it straight? Get to a damned mechanic! Preferably a dealer, but certainly a professional. A body shop that's Porsche certified if you don't like dealers. It's fun to work on our cars, but life-critical stuff should be handled by people with formal training, and in this case, people less likely to hurt themselves. Would you ask a neighbor's help with a troublesome cardiocatheterization?
And no, this isn't a 'useless' reply. It's just not what you want to hear, it's what you need to hear. If I had the shop instructions lying beside me I wouldn't copy them. For an owner, the instructions are: Pick up phone and make appointment.
I'll send the airbag back to the vendor and ask him to look it over. I think he will find something "not right" about its shape.
In addition to the wheel, I installed a few interior trim pieces I bought, that I would not have had the guts to install myself were in not for this and one other forum. The information available here is fantastic. So I can take the bad with the good, if you will.
thanks for the kind words. there's actually something irregular about the airbag I bought. Believe me, I spent enough time with this thing, that I know the process very very well. The flat wire harness does not seem to be the culprit, as it seems to lay in place perfectly for the prior airbag. In fact, I went ahead and put the old airbag into the new wheel, and it slid in very smoothly, clicked as it engaged the wire retainer in the rear, and required no pressure at all.
Casino_Royale
Sep 2, 2015 12:24 PM
