I am confused and need help with my new DRL lights...
Old Dec 13, 2011 | 04:48 PM
BSB911TT's Avatar
BSB911TT is a jewel in the roughBSB911TT is a jewel in the roughBSB911TT is a jewel in the rough
Can anyone figure this out? Am I missing a part? So the DRL's are plugged in. The only time I can get the LED bottom row of lights to turn on is when the car is OFF & I flip the switch over one notch past Home (the fogs) When the car is ON only the Daytime running light works? In every position only the little middle light work again when the car is running.
Im I missing something?
Old Dec 13, 2011 | 04:55 PM
DirtyVegas's Avatar
DirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud of
Yes, only the middle bar will be on. If you want the entire bottom LED row to come on you have to turn on your fog lights by pulling on the light switch.
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
Old Dec 13, 2011 | 04:56 PM
TT2911's Avatar
TT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really nice
Thats because you did not buy DRL's, you bought an exact replacement of your OEM lights that use LED's instead of regular bulbs..................
We tried to clear up this confusion in other threads. ROTtec calls them DRL because in a Canadian spec car (which comes with OEM DRL function) you are converting to LED DRL function.
The good news is, it's a pretyy easy fix. Search the threads for my write up on installing a Dectane DRL module. The cost is about $50 and can be done with no special tools in about 1 hour. Then you will have true DRL function with the bottom row of LED's.
Old Dec 13, 2011 | 05:36 PM
BSB911TT's Avatar
OK THANKS guys! I remember people talking about the Dectane module but to be honest I never fully understood it. I do now. I will look into it.
Old Dec 13, 2011 | 05:47 PM
cavsct94's Avatar
cavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to behold
Couldn't you just reprogram a US car to do whatever the Canadian cars do?
BSB911TT's Avatar
Is there any negative adverse effect with pulling out the light switch and keeping it out every time I turn on my lights or is it just more manual labor & inconvenient than anything?
Old Dec 13, 2011 | 06:39 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
It's just more of an inconvenient, IMO. Every time I drive my car at night, I would use the fog light function as an aid to the regular lights. Been doing it for the past 4 yrs. The fogs still work every time I turn them on.
Old Dec 13, 2011 | 06:55 PM
TT2911's Avatar
No adverse effects at all, other than your other light bulbs will wear out sooner since they will get more use.
Some folks don't mind manually turning on the lights or even driving with their full headlights on for safety. But true DRL function would give you just the lower row of LED's on with no other lights on the car turned on, and it happens automatically.
Old Dec 13, 2011 | 07:36 PM
DS997c2s's Avatar
DS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to behold
You need the TFLM03 module to get DRL functionality in the US
mxracer
Dec 28, 2015 08:17 AM
miken168
Oct 6, 2015 09:21 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
nagual911
Oct 1, 2015 01:52 AM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
