Refinished climate control buttons
Old Jan 7, 2012 | 08:37 PM
GBBc2s's Avatar
GBBc2s is a splendid one to beholdGBBc2s is a splendid one to beholdGBBc2s is a splendid one to beholdGBBc2s is a splendid one to beholdGBBc2s is a splendid one to beholdGBBc2s is a splendid one to beholdGBBc2s is a splendid one to behold
For those that had the flacking buttons, I had them refinished at stickynomore.com. They look great! The wording even lights up with the correct lighting color match. Here are some before and after pictures.
Old Jan 7, 2012 | 08:39 PM
MileHigh911's Avatar
MileHigh911 is a jewel in the roughMileHigh911 is a jewel in the roughMileHigh911 is a jewel in the roughMileHigh911 is a jewel in the rough
Look great! Good job!
Old Jan 7, 2012 | 08:46 PM
last911's Avatar
last911 has a spectacular aura aboutlast911 has a spectacular aura about
Congrats!
You now have something in common with most Ferrari's.
Old Jan 7, 2012 | 08:51 PM
GBBc2s's Avatar
Thanks! I just could not justify the crazy amount for a new unit.
Old Jan 7, 2012 | 08:52 PM
onewinwon's Avatar
onewinwon is infamous around these parts
Looks nice! Was it easy to remove and install back?
Old Jan 7, 2012 | 08:55 PM
GBBc2s's Avatar
Originally Posted by last911
Congrats!
I know...I discovered them from their forum. With this frequent problem I am surprised others have not gone this route. It was really quite easy. It must have taken me one hour top to do the job from start to finish.
Old Jan 7, 2012 | 08:57 PM
GBBc2s's Avatar
Very easy considering I am not the tinkering type.
Old Jan 7, 2012 | 09:18 PM
FatArse's Avatar
FatArse is infamous around these partsFatArse is infamous around these parts
How much to replace? Any guidance on how to pop them off?
Old Jan 7, 2012 | 09:47 PM
GBBc2s's Avatar
The cost was $75 to have my old buttons refinished. They are not new.
Here are some directions:
1) Remove the side carpeted panel that is on the inside of the foot wells beside the PSM on both sides. There is one hex screw.
2) Once the carpeted panels are removed, you will see two hex screws attached to the side panels of the PCM......unscrew those.
3) Slide the the PCM side panels with a slight upward motion and pull towards you. The clip should give at the top.
4) On both sides of the exposed climate control, you will see an opening revealing metal clips. Press both at the same time and slide unit out or one trickis to do one side at the time slightly pulling it out then doing the other.
5) Unplug the black and red plug
6) Back of the climate control you will see 4 hex screw (size 6)....remove.
7) Pull apart exposing circuit board. Remove 9 screws.
8) Gently separate the rubber buttons from the front plate facing down.
9) While holding the plate facing down, reach underneath and push the LCD up very slowly. This is important. There are multiple layers that sit on top of each other that you don't want to loose order of. Carefully place the LCD in a safe place.
10) This is the tricky part. Each switch has two legs that have to be pried Away from each clip. I used small butterknife? You will need to manipulate the switches out. Trust me, they will come out.
I sent them out, got them back and installed.
Hope this helps!
Old Jan 8, 2012 | 12:51 PM
onewinwon's Avatar
Thanks for the DIY !
Old Jan 8, 2012 | 01:24 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
How in the world did your buttons get to that state?
You must be touching some pretty toxic stuff or eating the wrong kind of food.
Old Jan 8, 2012 | 01:37 PM
Clay1G's Avatar
Clay1G is a glorious beacon of lightClay1G is a glorious beacon of lightClay1G is a glorious beacon of lightClay1G is a glorious beacon of lightClay1G is a glorious beacon of light
These buttons look great. How is the finish different from stock or is it?
Old Jan 8, 2012 | 01:43 PM
Abdon's Avatar
Abdon is a jewel in the roughAbdon is a jewel in the roughAbdon is a jewel in the roughAbdon is a jewel in the rough
AWESOME!!! Thank you! I was about to take the Sharpie marker to mine! lol!
Old Jan 8, 2012 | 01:48 PM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
Excellent fix! Thanks for sharing.
Old Jan 8, 2012 | 06:38 PM
GBBc2s's Avatar
I hear you....the buttons were peeling when I got the car and it just started to slowly get worse over time.
