Dead Battery
Old Feb 26, 2012 | 12:55 PM
Mazzta's Avatar
Mazzta is infamous around these parts
Dead Battery
Battery Moll 570 o59 o57
Hallo my name is Willie and I have a 997 S Red Cabrio. Since it is my summer car in Germany, during this winter the battery went totally dead.
I took it out already to charge it, but I am little bit afraid about which charger to use. Is any special advice I should follow?.
Thank you in advance for any clue you may give me
Old Feb 26, 2012 | 01:19 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Battery woes...
If the battery is 3 years or older.... replace it with a new battery. Typically the Porsche cars EAT batteries for breakfast. Replace with a NON Porsche battery. They last longer and have fewer issues!!
Old Feb 26, 2012 | 02:03 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
If the battery is just low (no bad cells) and can recover by charging it, you do not need to remove it from the car for charging. Just use the Porsche (dual mode) maintainer or the CTek equivalent -
HERE HERE
. In Germany you need the european 220V version, of course.
Old Feb 28, 2012 | 11:10 AM
Mazzta's Avatar
Thank you guys
Bought it in ebay should be home in short.
I took the battery out due there is no electricity connection in the garage.
Battery is not that old.
Next winter I will try the solar charger. I used once in my boat and worked ok.
Old Feb 28, 2012 | 11:29 AM
hroussard's Avatar
If you use the CTek charger... be prepared.. it will take several days before it will be charged completely, especially if you charge through the cigarette lighter socket but... it does work .. :-)
Old Feb 28, 2012 | 01:20 PM
wseikow's Avatar
wseikow is infamous around these parts
I use ctek for winter storage in Montreal. No problems at all
Old Feb 28, 2012 | 01:21 PM
Mazzta's Avatar
Ctek mxs 5.0
Well the car is under a "limited driving period" meaning with this that I am not allow to use it from April 1st till Octuber 31st.
Battery is out the car and in the celler, I will post how long it take. Battery is totally dead.
Old Feb 28, 2012 | 02:30 PM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
You'd better peel the sticker off middle top (where it's perforated) and using a coin, open up each of the 6 cells to make sure they are full to the L hook (use a flashlight). If not, top off each cell w/ DISTILLED WATER only. Otherwise, you'll over cook the battery (w/ most if not all maintainers) yielding a still dead battery...
Old Mar 3, 2012 | 11:26 AM
Mazzta's Avatar
I connected the charger
CTEK MXS5.0 at 18:00 hs Friday, (battery was completely dead) about 11:30 that day the read light showed up, I pressed the mode botton, and the charger has re-started and went right away to step number 3. In the morning at seven the charger was in step 7. Then, took 13 hours from dead to full charge.
I installed it back in the car, no alarm sound, everything was full in operation. Turn the key on and the engine moved slow, very slow. three crank and he was "back to life"
Wanted to mentioned, last time I started the engine was December 5. therefore it stayed three months sleeping
vpr80
Mar 6, 2021 12:11 PM
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
007 Vantage
Oct 8, 2015 08:35 PM
ek1
Bentley
Sep 26, 2015 11:54 PM
