DIY 997.2 oil/filter change
Old Apr 24, 2015 | 08:11 PM
  #31
tiyyara's Avatar
tiyyara is infamous around these parts
for those who plan to own their cars for sometime, a durametric to reset the service interval may be worth it. The "amateur" version is good for 3 vins.
So if 2-3 people buy it together it would pay back in a couple of oil changes (you would be ahead in 2 years if 3 people share one)
Old May 2, 2017 | 08:42 PM
  #32
HP11's Avatar
HP11 is infamous around these parts
Reviving this thread to add a little more info. Just finished changing the oil on my 2011 TTS.
After I removed the drain plug, 5.5 to 6 quarts of oil gushed out within 3 to 5 mins. Oil was warm to the touch. 30 mins prior, I drove around to get engine to operating temperature per the electronic oil level gauge.
After those 3 to 5 mins, the oil trickled out very slowly for 45 mins. Picture a thin, continuous line of oil. After those 45 mins, oil dripped out for approx 2.5 hrs.
When I refilled the engine with oil, I ended up using 8.5 quarts.
I had no intention of waiting 2.5 hrs for the dripping to continue....however, I was convinced I had the wrong oil filter to replace what I removed. See pics below.
ID:	475600   Click image for larger version
ID:	475601   Click image for larger version
Old May 2, 2017 | 08:50 PM
  #33
HP11's Avatar
When I initially compared the old filter with the new filter, I was convinced it would not fit. The center opening's diameter didn't match. Newer filter was smaller. After calling dealer to confirm part numbers, he consensus was for me to return to dealer to exchange my faulty filter. Well, living 55 miles from dealer and wanting to finish the job, I decided to take another look at the new filter. The white felt-type matierial in the center of the oil filter is flexible. Apply pressure and it gives way. See third pic. I had to "force" the filter onto the base of the filter canister and the result was a very snug fit. Changed out green o-ring that I paid $10 for and screwed the black plastic canister cap back on and finished.
First Porsche and first Porsche oil change, so, didn't want to screw things up.
Old May 2, 2017 | 08:57 PM
  #34
HP11's Avatar
One last thing, car is a beast with a fresh oil change. I mean...Turbo is smoother and faster/more eager to run. Gears seem to engage faster.
Definitely an easy oil change. Didn't even lift the car off the ground. I didn't check the oil level after filling until the engine was at operating temperature. I drove to the gas station and back. My first fill consisted of 7 quarts, then 1 quart, then half a quart. Oh yeah, had to buy a 36mm socket from Lowes to remove oil filter canister top.
Glad I didn't pay the dealer $220 to $300 to do this. Mind you, I almost did but refused to wait 2 to 3 hours for the service to be completed...I've got other things to do
Cheers!
Old May 3, 2017 | 09:26 AM
  #35
jhbrennan's Avatar
Good job - DIY successes always feel good but...
Did you change transmission fluid too?
Old May 3, 2017 | 10:11 AM
  #36
HP11's Avatar
Originally Posted by jhbrennan
Good job - DIY successes always feel good but...Did you change transmission fluid too?
No, that's the strange thing. Doesn't make any sense...maybe I was just overly excited I did the job and "thought I felt a change". The car just felt more connected between transmission and engine somehow. Power just felt more directly put to the ground. Car has 15,2xx miles.
911TurboRules
Jun 23, 2024 06:59 AM
Money2536
Jan 19, 2022 08:22 AM
alevine
Nov 4, 2015 10:05 AM
away
Sep 4, 2015 12:30 PM
00aston
Aug 27, 2015 12:01 AM
