Moved rear deck fan. Need suggestions on old hole
Old Aug 14, 2012 | 07:36 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
Originally Posted by PSPorsche
Go to Home Depot. Get the mesh people use to DIY front grills. Cut out a circle with four "lobes" to match the outline of the fan and four screw posts. Paint it black. Screw in the "grill" using black screws and black washers to make it look like an extra air vent.
+1
This is a great idea and your cheapest alternative.
Old Aug 14, 2012 | 08:40 PM
mattgarrett's Avatar
mattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the rough
Originally Posted by Darthvader
Where can I get a chunk?
You can buy a small sheet of carbon fiber. You can cut it with a dremel and sand the edges to a smooth finish. Looks great. I did some bumperette covers on my 996 when I installed my TPC turbo. They looked great and it was cheap. you could even finish the edges with automotive edging if you desired. One of my buddies gave me the carbon fiber sheet. I will find out where he got it and post it for you.
Old Aug 15, 2012 | 06:55 AM
Darthvader's Avatar
Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !
Thanks that wold be great
Old Aug 15, 2012 | 03:21 PM
Darthvader's Avatar
Which shape looks more appealing?
Old Aug 15, 2012 | 04:34 PM
The bottom one. Waiting on call from my friend about carbon fiber sheet. I think you can just google it in amazon and find a sheet of fiber. I will post as soon as I find out.
Old Aug 15, 2012 | 10:12 PM
bbywu's Avatar
If it fit it could have stayed put. Anyone know of a replacement fan with a low profile?
Yes.
SPAL
High HP turbo builds often use a MAF-less intake system combined with larger Y pipes, both of which cause the center fan to collide with the aftermarket engine parts. Contact joetwint/EVOMS - they have spec'd a SPAL fan with a custom bracket that should provide you with a much lower profile fan over the OEM Gate fan.
Old Aug 15, 2012 | 10:13 PM
bbywu's Avatar
Old Aug 16, 2012 | 05:58 AM
Darthvader's Avatar
Now you tell me
Old Aug 16, 2012 | 10:44 PM
bbywu's Avatar
Now you tell me
Search engine is your friend.
Old Aug 17, 2012 | 06:04 AM
http://dragonplate.com/ecart/product.asp?pID=3741
Sheets of carbon fiber. This is where my buddy got his. I searched and there were many more.
Old Aug 17, 2012 | 07:30 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Cut a piece of flat stock carbon fiber and use small black bolts to attach it to the original holes.
I would like to see an example of this as I think it would look odd. To me, a piece of non-functional carbon fiber screwed over a hole which, if left alone, would allow heat/air transfer would serve no positive purpose.
Old Aug 17, 2012 | 07:42 AM
Darthvader's Avatar
Prior to moving the fan to the right there was no gaping hole. So the airflow really is no different. The plate would be purely aesthetic with a nice Porsche shield place in the center. I like a clean compartment and that's what I am shooting for here.
Old Aug 17, 2012 | 01:22 PM
Carbon fiber for the most part when used as trim is non functional and there are many people that like the look of it, me included.
Old Sep 1, 2012 | 01:10 PM
Darthvader's Avatar
werkzrs
Apr 23, 2020 12:03 PM
rnl
Aug 26, 2015 02:36 PM
I'mAllIn
Aug 25, 2015 09:44 AM
saline
Aug 19, 2015 12:25 PM
Lifeisgood2
Aug 19, 2015 10:02 AM
