Moved rear deck fan. Need suggestions on old hole
Old Aug 13, 2012 | 05:12 PM
Darthvader's Avatar
Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !
Trying to spruce up the underside of the lid. Man the hole is so ugly. What can I do to make it more appealing to the eye.
Suggestions please people.
Old Aug 13, 2012 | 05:20 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
got a couple of questions... do you have a reason to move it? as you can see, the way that fan works is by pulling fresh, cold air from the outside of the deck to the inside via that hole. if there is no hole on your deck behind the new location of your fan, you just render it useless... what year is your car? is that a turbo lid?
Old Aug 13, 2012 | 05:40 PM
Darthvader's Avatar
Yes there is a hole the same size next to it. It was move to clear the intake. The stock intake was taken out to clear the wing pistons on the TT lid now on a C4S 997.1
Old Aug 13, 2012 | 10:03 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Yeah. Close the deck so you don't see it. Problem solved. Otherwise run two fans. Mine doesn't come on anyway.
Old Aug 14, 2012 | 03:55 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
Bling it up with a 15" LCD screen )
Old Aug 14, 2012 | 05:22 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
Subwoofer...
Old Aug 14, 2012 | 05:51 AM
mattgarrett's Avatar
mattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the rough
Cut a piece of flat stock carbon fiber and use small black bolts to attach it to the original holes.
Old Aug 14, 2012 | 09:49 AM
Darthvader's Avatar
Where can I get a chunk?
Old Aug 14, 2012 | 11:52 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
It looks like the fan motor actually screws to the round plastic piece. So maybe you can find another fan unit remove the motor (which looks like what won't clear your intake) and use that to cover the hole.
Old Aug 14, 2012 | 11:56 AM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
I'd locate a second fan.
Old Aug 14, 2012 | 11:58 AM
Darthvader's Avatar
Hmmmm
Old Aug 14, 2012 | 11:59 AM
Darthvader's Avatar
If it fit it could have stayed put. Anyone know of a replacement fan with a low profile?
Old Aug 14, 2012 | 01:14 PM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Originally Posted by Darthvader
Hmmmm
I think that MJFDDS was suggesting that you buy a used fan and disassemble it (remove the fan and the grill). Then use the frame to mount a flat hole cover. Maybe cut apiece of flat plastic to fit the frame and then cover it with 3M vinyl to get that highly desired carbon fiber look.
There's a fan for sale on ebay for $35 http://www.ebay.com/itm/USED-ORIGINAL-PORSCHE-911-997-CARRERA-GT3-TURBO-GT2-ENGINE-BAY-AUXILIARY-BLOWER-/280910646592#vi-content
Old Aug 14, 2012 | 07:26 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
lmao.
I wouldn't install anything there, You don't need two fans, unless this is a track rat.
Old Aug 14, 2012 | 07:34 PM
PSPorsche's Avatar
PSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond repute
Go to Home Depot. Get the mesh people use to DIY front grills. Cut out a circle with four "lobes" to match the outline of the fan and four screw posts. Paint it black. Screw in the "grill" using black screws and black washers to make it look like an extra air vent.
