Another offset Question
Old Aug 22, 2012 | 10:16 PM
Chris_FL's Avatar
Chris_FL is a jewel in the roughChris_FL is a jewel in the roughChris_FL is a jewel in the rough
Would these work on my 997.2 NB at all?
Stock height (may do H&R springs eventually)
Rear 19", ET31, 11" w/ 295/30
Front 19", ET41, 8.5" w/ 235/35
Old Aug 22, 2012 | 11:06 PM
tunedgoody's Avatar
tunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of light
front is fine the rear is aggressive. You might need to do tire stretch. Roll fender or shave fender for sure. let's say after market in Okay looking flush(no fender roll needed) is about 21mm tuck in from your spec.
Old Aug 22, 2012 | 11:09 PM
tunedgoody's Avatar
it is about 21mm closer to fender from this one in the pic. So I would say it might stick out or being really close to fender.
Not impossible. It could be done with stretch tire and camber.
295 won't do the job
Old Aug 23, 2012 | 11:43 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Not worth attempting IMO. You would surely need to roll the fender and it may not look right with that much offset in the rear.
Old Aug 23, 2012 | 12:50 PM
jhbrennan's Avatar
OEM rears are ET 67mm correct. If so, your ET 31 will be pushed out 36mm or almost 1.5 inches - way too much in my opinion.
Old Aug 23, 2012 | 02:08 PM
wolfnards's Avatar
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
with RSS Spacers installed, I'm running
Front: 19x8.5 ET46 (295/30)
Rear: 19x11, ET36 (235/35)
I think it's just right. ET31 might be too aggresive, but ET36 may work for you.
Old Aug 23, 2012 | 03:03 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Wow your fronts are wider than your rears. Now thats a setup
Old Aug 25, 2012 | 02:46 PM
Chris_FL's Avatar
Thanks for the replies guys, on another note, from what I gather... factory 997 Turbo wheels will work just fine, right?
Old Aug 25, 2012 | 04:30 PM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
I'm running Turbo offsets and fitment is perfect.
Old Aug 26, 2012 | 12:33 AM
tunedgoody's Avatar
Did you mean 295 in the back and 235 in front ??
Do you have photo of you your set up?
Do you need to roll fender for that ?
I'm about to buy spacer ti push my wheels out a little bit. and I'm doing calculation.
Old Aug 26, 2012 | 03:13 PM
wolfnards's Avatar
very good catch, sorry about that.
should be:
Front: 19x8.5 ET46 (235/35)
Rear: 19x11, ET36 (295/30)
Old Aug 26, 2012 | 04:23 PM
tunedgoody's Avatar
should be:
no worry
But I think OP has narrow body. I'm not sure how much different in NB and WB.
991carreradriver
Aug 30, 2015 04:16 PM
HpizKing
Aug 30, 2015 04:42 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
