How I route my Battery Tender cable
Old Dec 15, 2012 | 10:20 AM
stevefrommn's Avatar
stevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura about
I use a Ctek which is like Porsche's maintainer. The wires are run down the side of the Frunk. There is no interference any where and the wire fits easily out the front even with lid closed tight. Been doing it this way for over 12 years. First on my 996 and now on my 997. I don't know if 991 Frunk space looks the same. I hope pics show up OK.
Old Dec 15, 2012 | 10:50 AM
Steve997S's Avatar
Steve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond repute
I just use the receptacle in the console and close the door on the wire. It doesn't crimp the wire at all so there's no issue with fraying. It also has no impact on the door seal or the paint on the rocker.
Old Dec 15, 2012 | 11:16 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Same for me - cig adapter and close the passenger's door on the wire. Plus I can use the car cover this way without worrying about the cord scratching the paint.
Old Dec 15, 2012 | 02:41 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Here s what I did,,, Just came out from the battery up to the windshield over the plastic.. You can close the hood with pleanty of room not to hurt the cable and you are not over the cars finish where it comes out from. Tuck in with battery when not in use.
Old Dec 15, 2012 | 02:55 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
PI plug directly in the cigarette lighter, leave the window a little crack open, plug the charger into the power socket and I am done.
Old Dec 15, 2012 | 03:19 PM
ELUSIVE's Avatar
ELUSIVE is infamous around these partsELUSIVE is infamous around these parts
Yep. This.
EASY!
Old Dec 15, 2012 | 06:02 PM
jhbrennan's Avatar
Porsche purposely put a notch on the passenger's side door molding (bottom) just for the charging cable - no need to hang it out the window.
Old Dec 15, 2012 | 06:05 PM
hroussard's Avatar
Thanks, I learned something today!
Old Dec 16, 2012 | 07:36 AM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
FYI. There is a cig adapter in the centre hump of the passenger footwell too.
Old Dec 16, 2012 | 07:39 AM
ELUSIVE's Avatar
Right. That's the one that I use. Makes it very easy for the cord to come straight out the bottom of the passenger door.
Old Dec 16, 2012 | 07:56 AM
shtfrbrains's Avatar
shtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud of
Exactly. Me too. The Porsche tender is designed to be used this way.
Old Dec 16, 2012 | 01:07 PM
Well I see no notch in my door. But even if there is I don't want anything on the side of my car because or other car on one side and need to get my Pugsley down on other side. Also floor on sides of car usually wet with melted snow from 4runner. In Minnesota winter is a constant mess. So in front of car is dry and I don't have to worry about someone getting tangled in wires. So I'm sticking with my method.
Old Dec 16, 2012 | 02:22 PM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Minor nitpick: It's called a battery charger and/or a battery maintainer. "Battery Tender" is the brand name of a different charger.
I've got the Ctek Multi US 3300. It doesn't come with a plug for the cigarette lighter outlet. It has two interchangeable connection leads, one with clamps and one with eyelet terminals. I've got the eyelet cable connected directly to my battery and the clamp cable connected to my lawn tractor. There's a nice watertight connector that connects to either cable.
Old Dec 16, 2012 | 02:31 PM
bbywu's Avatar
FYI...
There is a cigarette adapter available - CTEK 56-263
Old Dec 16, 2012 | 07:48 PM
Minor nitpick reply. I have both a Tender and a Ctek that's why I called it a tender I guess. By the way a charger usually puts out around 2 amps when the battery reaches full charge. This is called a trickle charger. You do not want to use one of that type for storage. After a few months on trickle charge you may ruin your battery. The maintainers like Ctek or the battery Tender back off to near 0 amps at full charge so they wont cook your battery. The Ctek is a very smart charger.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
pwdrhound
11
Nov 25, 2015 01:18 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
