Coolant Leak Cause? Pics Attached
Old Apr 8, 2013 | 01:19 PM
Johnny DB's Avatar
I noticed my coolant level going down slightly last year before putting my car in storage. When I took it out this weekend I looked at the cardboard I put underneath the car with no obvious signs of anything having leaked and the coolant level was the same as it was when I put it away.
I did notice white powder on the black thing (?) behind the coolant cap. See attached pictures
I still have version 1 of the coolant cap...
TIA
Old Apr 8, 2013 | 01:31 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
That's the purge cap of the expansion tank. they sell all the parts to replace that part but you will be better by replacing the whole tank. it will come with the latest version of the cap...
Old Apr 8, 2013 | 01:53 PM
Johnny DB's Avatar
Thanks Joel.
Why are you recommending replacing the whole tank when I can replace the purge cap? I read that replacing the tank was expensive?
Do you have a part number for the purge cap?
J
Old Apr 8, 2013 | 03:37 PM
JoelPirela's Avatar
here they are:
996.106.347.02 bleeder valve
999.707.370.40 o-ring 1
999.707.371.40 o-ring 2
and just get the cap ending in 04 for good measure!
Old Apr 16, 2013 | 03:37 PM
Johnny DB's Avatar
Joel,
I changed the blue coolant cap to the latest version. I also bought the o-rings but to my surprise, the PRV did not have any when I opened it up nor does it have any o-ring grooves!?!?
J
Old Apr 16, 2013 | 05:52 PM
kchociej's Avatar
kchociej is infamous around these partskchociej is infamous around these parts
The tank WILL leak on you...it's a question of when, not if.
Myself included I personally know 2 other 911 owners who had to replace their tanks. I found mine online for under $200 if I'm not mistaken. ...few write ups on line of how to do it, if you're handy at all.
The job itself is a HUUUUUGE pain in the a$$.
Old Apr 17, 2013 | 02:38 AM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
well, damn. I just found a weeping leak in my front radiator, so if the tank is failure prone I guess I am in to replace the front radiators, the tank, and the water pump, as I may as well do it all the same time
Old Apr 17, 2013 | 06:39 AM
terpsred's Avatar
terpsred has a spectacular aura aboutterpsred has a spectacular aura about
IslandS62,
how did you spot the weeping in the front radiator? mine are soo far back unless it was right on the face, I'd never see it. did you remove the underside of the front bumper area to see this?
Old Apr 17, 2013 | 10:13 AM
IslandS62's Avatar
I found pink residue under my front bumper, and after removing the underside panel I can see with a flashlight the seam of the radiator has telltale pink crusty coolant on it. Not a bad leak, no puddle, but it needs addressing.
Old Apr 17, 2013 | 02:20 PM
Johnny DB's Avatar
PET diagram:
Mine taken apart...no o-rings and don't see anywhere logical for them with this design:
ID:	233411   Click image for larger version
ID:	233412   Click image for larger version
Old Apr 17, 2013 | 02:22 PM
Johnny DB's Avatar
A few of the screws were loose so I replaced them and zero coolant loss since.
Old Apr 22, 2013 | 01:52 PM
Johnny DB's Avatar
Update: changed the coolant cap and continue to have no coolant loss.
salesguy01
Mar 25, 2019 09:39 AM
viprklr
May 23, 2018 11:33 AM
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
Michael_s
Sep 11, 2015 08:03 PM
LiquidElephant
Aug 27, 2015 06:17 PM
