997.2 Bose speakers better than 997.1?
Also...bose is notorious for building speakers with strange impedences so that it makes change out difficult. I wouldn't assume that a 14 ohm speaker from a 997.1 would be the same strange impedence in the 997.2...they might put in a 2.47 ohm just for ****s and giggles.
I have a nice Polk Audio SDA sound system with the SRS2 and CRS+, Parasound, Carver, Adcom, NAD, amps, and other speakers all of which could hold their own as mains. My home is set up for listening. I know that the car is the last place for true audiophile stuff, but a good system is fine for listening in a Porsche. Also, my Porsche is fine for listening compared to my other rattlesound cars.
I made a new thread just now for my install starting with the tweeters. It's here:
https://www.6speedonline.com/forums/...ml#post3833041
I hope it helps! It did involve some permanent trimming, but it's hidden, for the most part reversible, fairly easy (about 1/2 hour) and looks stock.
Per gasongasoff, it sounds like the bose system uses 1 ohm drivers. Per others, it sounds like 997.1 and 997.2 bose are same part. Based on this, I definitely would not replace existing speakers with 997.2 unless existing are blown.
In terms of replacement with aftermarket, just about anything would sound better than the stock paper cone bose speakers. The problem is...good luck finding a 1 ohm replacement (hence the logic of using a non-standard impedence...if your speaker blows, you must use bose). A really good website is parts express. They just might have something that would do it.
If you can find a better quality (look for something with a butyl rubber surround) at the right size and right impedence, it is likely you will get a good bang for the buck improvement in sound. Otherwise...again, slippery slope to full system changeout.
This tread is confusing me. Are we saying that we can simply replace the tweeters in the bose system with focal units and it would already increase quality of sound? Are we saying the focal impedance matches the bose tweeter units being replaced?
Gasongass off mentioned two things that I had not considered which may damage the tweeters, the crossover and the capacitors. The crossover to eliminate the midrange signal as it is shared with the tweeters per the wiring from the bose amp, and the capacitor to help with any sudden surge on the tweeter. Even without the crossover the sound is immediately better, but Tito had pointed out in my thread that he found a bunch of tweeters with built in crossovers. I have a feeling that even a partsexpress tweeter with built in crossovers would be far superior to what was in my dash previously. I would think the money they put into the sound system was in priority: Double din nav and cd player, then the fiber optic bose amp, the subwoofer and enclosure, and lastly the crappy and I really mean crappy speakers. In every system I've ever had the end of everything comes through the speakers, so your money is best spent there which is not what I'm finding in the Porsche.
